Question about Acer CR-5130 4.9MP Digital Camera
Acer CR-5130 Digital Camera
The optical zoom is out of position all the time and all the fuction dosen't work.
  • Anonymous Oct 11, 2008
    ho comperato delle schede di memoria SD da 1,2,4 GB ma anche dopo averle formattate dal pc e dalla fotocamera, sul display mi continua a comparire il segnale errore! come posso fare?
I want to place a 2gb memory card in the acer cr5130 but always i have the message card error .. i have tried several cards but always the some... please advice
Posted on Aug 17, 2008
Just purchased it from bid tv it has 4xdigital zoom would i have been better to get optical zoom instead this is my first camera
Digital zoom enlarges the ccd image and will become more pixelated the more you zoom and optical zoom uses an actual lens to magnify the image coming into the camera. optical zoom is better than digital zoom.
Sep 25, 2009 | Vivitar 7.0MP Camera Digital Camera with...
Optical zoom problem in movie mode
Your camera is not broken. That's by design. Canon cameras do not allow optical zoom use while in movie mode. Canon claims that using the optical zoom in movie mode would cause excessive noise in the movie. However, you can use digital zoom in movie mode. You'll need to go into the menus (press the menu button) and turn digital zoom "on" if it's currently off.
Oct 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 01, 2008 | Olympus Camedia C-720 Ultra Zoom Digital...
Camera is optically blind after water dry out
It sounds as if you have water inside your lens. There may be water on the CCD (its like the film for digital cameras)...You could try to blow compressed air into the lens (on the side of the zoom and into the lens itself), replacing the whole lens unit, or opening up and drying out the lens unit. - each of these options are listed in increasing difficulty.
Jan 17, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Zoom function
Yes. This camera has 3x optical zoom and 4x digital zoom. However digital zoom cannot be used in 2880 x 2160 size. Optical zoom: It is approximately 5.6 - 16.8 mm. (equivalent to 38 - 108 mm on 35mm film camera) Digital zoom: It extends to 4x from telephoto end (108mm) of optical zoom.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
Optical vs. digital zoom
It's important to understand this difference, as you could be disappointed with the results if you use one rather than the other. Optical zoom works like the zoom on a traditional film camera. When you push the button to zoom in or out, physical lens elements move inside the camera, reducing the field of view and making the object you're shooting appear closer. Digital zoom, on the other hand, has no moving parts. The camera interpolates a small portion of an image to artificially restore the file to its original size. Using its electronic brain, the digital camera analyzes what it sees and digitally zooms in, usually two or three times closer. Unfortunately, digital zoom also reduces the resolution of an image, so your picture will tend to be more pixilated than the same image taken with an optical zoom camera. If you're just snapping an image to e-mail to a friend, this loss of resolution won't be so noticeable. But in situations where the highest quality counts, skip the digital zoom and use your PC's image-editing tools to zero in on your subject.
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Super Zoom
In addition to the optical zoom, this camera is equipped with a super zoom and digital zoom for taking telephoto and wide-angle shots. The super zoom and digital zoom cannot be used at the same time. Super zoom is used to extend the optical zoom up to 14× magnification. However, the resolution is automatically fixed at 1600 ×1200. Digital Zoom is used to extend the maximum optical zoom to approximately 40x. However, pictures taken with the digital zoom may appear grainy. Camera shake is likely to occur at these higher magnifications, please see “camera shake” question for further details on this.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Super Zoom
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Acer CR-5130 4.9MP Digital Camera Logo
224 people viewed this question
Top Acer Cameras Experts
Joseph Hoffmann
EE Eddie
Are you an Acer Camera Expert? Answer questions, earn points and help others
