To download music from computer to your cellphone,with the use of your memory card,you can transfer all music file to it's music folder.If you have a multi media card reader.
Or you can transfer music using your phone and a data cable and a software tool to synchronize your phone to the computer.
Download this file : NOKIA PC SUITE
To transfer photos/files from cellphone to computer..You need a card reader.Remove the memory card from yuor cellphone place it on the card reader then connect the usb cord from the card reader to the computer..Then go to the MY computer,then go to the disc either drive a..c..d that was added.and try to open the drive that was added..
If you have a cable for your Nokia cellphone and you have a Nokia PCsuite, then just connect your cellphone to your laptop via the USB slot.
If your cellphone and laptop has Bluetooth, you can transfer your files wirelessly. Just connect them via bluetooth and choose "transfer" or "copy" the pictures you want to transfer then choose "via Bluetooth".
If you save the pictures in your cellphone's memory card, you can remove the memory card, insert it in a card reader, then insert the card reader into your computer.
If you want to transfer files from pc to the mobile device. Make sure the pc has a bluetooth turn on. Most of the laptops have a built in bluetooh , but for desktop computers you need to purchase a bluetooth adapter.
Once you have the bluetooh turn ON on your computer. Turn on the bluetooh on your mobile device.
From your computer. Right click on the file that you want to transfer and select send to bluetooth. Click on search for bluetooth device and then select the name of your cellphone ( or name you assigned for the bluetooth on your cellphone)Once you click the name, just go next . You will get a message saying accept bluetooh file on your cellphone, just accept the file and your done.
Mam Nina<
Is your unit equipt or have a USB? if that so,just simply connect it to yoyr PC,and anytime you have connected it a baloon on the screen of your pc will pops up to let you know that it is already activated.If that so,you can go to"my computer,Then right click for the" Removable disk (E)", or what is assigned in your comp..Once you click it you can see the files stored in your Cellphone.
Now,if you already opened the files,you can save your file( The picture you are saying) to your PC by this way:
1. Right click to the name of file you want to save or
Transfer.
2. a menu will appear and right click for the "Send"
3. A menu will appear and right click to the
" My Documents"
just follow these and your files will be saved to your PC ..
But when your CP dont have a USB?No problem,you can buy a USB bluetooth and install in your computer.
After installing it,you can perform transfering files just like the way you are sending bluetooth through cellphone to cellphone.( but to tell you to have a little patience in transfering or sending files becoz it has a little bit slower than a USB, the reason that USB is direct or line to line ,so it is more faster than a bluetooth which is through "signal."
Mr Dinesh
REM file extension appears when media files are saved to device memory and are not removed when the media file is transferred to a computer.
You cant change this..after transferring the media file to the computer, rename the file to remove the .rem extension.
dont you know how to transfer files from your computer.. if you have ur USB you can connect it to your computer and u can now transfer the file from your PC coming from your cellphone.... [email protected]
