Question about Dell Inspiron 2200 Notebook
Tv- laptop connect
I wanted to know if I can use a vga s-video cable to connect my laptop to my tv.. i was told thast the cable wouldn't bork if my laptop didn't have tv- out capability...so does it?
  • shoaibjee99 May 12, 2009
    I have inspiron 2200 Laptop which I wonna connect to my Analog TV, but my system doesn't support my TV. I use VGA to RCA cables but no display. Could you tell me is their any solution that enable me to connect my Laptop to my TV?
    Thanks
    Sam
    Genius:
  • 2,028 Answers
If you're laptop has a VGA port, then it is compatible to VGA devices. This is the general rule with just about everything VGA, whether it's a TV or laptop, if there's a VGA port then it's VGA compatible. Keep in mind that most TVs are not made to be computer monitors, so you may not get the resolution clarity you are expecting. Also, some VGA compatible TVs that can achieve the clarity need drivers in order to work properly. If you plug it in to find that the you don't have a good picture, search the manufacturer's site to see if the TV requires drivers. You can also do a Google search and read some of the forums, they can be very useful.
Posted on Jul 12, 2008
Yes
I have connected my laptop to my element tv via vga cord;sound is comin frm laptop..want the sound frm TV; THEN, I have a headset/microphone ... can I connect my headset/microphone to the TV?
If you need to get sound from your TV, you should have a sound input socket in your TV. If you have that you can connect an audio cable from your sound sound socket to your TV.
The second option is that your laptop and your TV should have HDMI ports. If its there, you can use an HDMI cable(instead of VGA cable)to connect the two. With HDMI cable, you will get both video and audio through that single cable.
If you need more help please let me know
Jul 02, 2017 | VIA Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
I want to connect my sony tritron tv to my hp laptop
If you Sony TV has a VGA video input socket then connect a VGA video cable to the TV and the other end of the VGA cable to the VGA video connector on your laptop.
Power up the TV and go to the Input selection Menu and select PC connector then boot up your laptop and the Windows video data will automatically to the TV.
You can toggle between the TV the LCD or both by pressing Fn key plus F4 key.
May 29, 2012 | HEWLETT-PACKARD G71340US Laptop
Want to know how to connect acer 3680 to tv
It depends on your TV
If your tv has a Computer VGA connection you can directly connect the VGA connector from the left side of the laptop to the connector on the tv
If there isn't then you could go buy a S-Video to RCA cable at radioshack and connect the S-Video port on the laptop to a video in connection on the TV
For sound you can connect the speaker/headphone jack on the laptop to the tv using a cable either going direct from 8mm to 8mm or from 8mm to RCA...either can be found at radioshack
Let me know if you need anything else!!
Jul 01, 2011 | Computers & Internet
Is it possible to connect the emachines E525 with an LG LCD tv if so how?
It is possible to connect your laptop to any LCD TV. For which you need to locate the external VGA port on your laptop. As your Laptop doesn't have S-Video port you would have to deal with the VGA port.
There are several adapters available in the market which can solve your problem:VGA to RCA orVGA to S-Video orDual VGA cable
Your LCD TV should be equipped with all the ports mentioned above that are:RCA (AV)S-VideoVGA In
But as I don't know the model Number of your TV I don't know whether your TV has S-Video or VGA ports but the RCA (AV) are the most common ones which I am pretty sure you would have.
Here are some pics of the cables.
^Dual VGA cable
^VGA to RCA or S-Video
You can buy these cables from the market and easily connect your system to the TV.
If you need further help, please feel free to contact me.
Aug 08, 2010 | Computers & Internet
HP Laptop to TV
You cannot connect VGA OUT to component IN on your TV without using a converter. However, You can connect VGA OUT from your laptop to VGA in on your TV using a VGA cable just as long as your TV has VGA in. You will need to hold the FUNCTION or FN key on your laptop while press the F4 or F10, whichever F key has the picture of the monitor on it. This will switch your laptop from LCD to external display or both.
May 02, 2009 | HP Televison & Video
What type to cable should I buy to connect laptop to tv
Youre laptop would have to have a video card that has a TV-out port... And for that you would have to run a S-Video cable from the TV-out port of your laptop to the S-Video port on your TV... I assume your TV has a S-Video port?
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Feb 10, 2009 | Philips 52 In. LCD HDTV
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
How do I connect my Laptop computer to my LCD TV?
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
Apr 12, 2008 | Computers & Internet
Dell Inspiron 2200 Notebook Logo
229 people viewed this question
Alun Cox
