Question about Thermos Stainless Steel Gas Grill
My grill has 5 burners. When I turn on more than 3 the flames get very low even though it is set to high. I have to shut off all burners and restart them to fix it, but I still cannot turn on more than 3. Any thoughts?
  • Anonymous Sep 25, 2008
    One burner works fine on its own. When I turn on another burner, the first burner gets really low, and so does the 2nd. Won't get above 150 degrees when all four are going because the burners are all so low.
    Champion:
  • 254 Answers
Your problem is that your regulator is not letting enough fuel through it. If you replace it make sure that you match the numbers up to the new one so it is sized correctly. If you need more help please comment me back thanks.
Hope this helps you
please rate me
Posted on Jul 20, 2008
I cleaned my grill to try and solve this problem. I blew out the burner and there's no debris in it. I put everything back and connected to the propane. I still only get a flame that is on low. ...
To get a high flame, do the following:
Be sure you have adequate gas in the tank to maintain combustion. If that checks out OK, start with step # 1.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Aug 09, 2011 | Char-Broil CharBroil 4637318 Grill
I have a brinkmann 4 burner. The cross over at the back of the burners has it's own flame. The back of the grill, even at the lowest setting is still very hot. Flames come up between the plates. On...
Sounds like a gas regulator problem. But, somewhat unusual, as most people complain of low flames. In any event, you will need to replace the Hose/Regulator Assembly. They run about $30.00 and can be found at any hardware store or home center, that sell gas grills and accessories.
As a safety measure, after turning off the gas tank, check each burner for blowout or rust through..
I hope this helped you and thanks for choosing FixYa.
Jul 31, 2011 | Brinkmann 810-8530-S Stainless Steel...
We have intermittent low gas flow to our Viking grill. We have replaced the burners and the regulator. It worked fine on Sunday but now today only the first burner lights (and it's low even though I...
Lynn, the problem lies with the gas regulator and the way you turn the tank ON. But it's readily solvable.
1. Turn the tank valve OFF & disconnect the hose from the tank.
4. Once the valve is fully open, light the burner farthest from the tank first and set it on HIGH.
Does the flame height look correct? If so, light the remaining burners the exact same way.
Do all the flame heights look correct? If so, your solved the problem. Always remember to
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. They run about $30.00 at any hardware store or home center that sells grills and accessories. Simply take you old one with you for comparison purposes.
Hope this helped you troubleshoot & solve the problem. Please let me know. Thanks.
Jul 06, 2011 | Viking VGBQ410-3RT Grill
Two problems:my left gas port will not distribute the gas to the burner:second the two other burners distribute gas at a low level even though the burner is on a high setting.I have replaced the tank and...
The problem is more than likely, the new tank. More specifically, the way you opened the ODP tank valve. In most cases, it is solvable,
1. Turn the tank valve OFF and disconnect the hose from the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion. slow). Once the valve is fully open
light the burner farthest from the tank first and turn the burner to HIGH. Did the burner light and
does the flame height look correct? If so, light the remaining burners the same way. Now, do all
the burners light and the flame heights look correct? If so, you solved the problem.
If the above did not solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It's easy to do and you can pickup one at any hardware store or home center that sells gas grills and accessories for about $30.00. Take your old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 29, 2011 | Jenn-Air Grilling
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
Hello, we have a 3 switch stainless grill that has NEVER heated up properly. It always seems to stay luke-warm. Please help.
First, how high are the flames when turned to high as opposed to the low setting on each of the 3 burners? If there's no significant difference in height between the two settings, here's what I want you to do.
Turn off the gas tank (that's assuming you are using a 20lb LPG cylinder) and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the Tank Valve ON very, very slowly, until it's fully open. Now, light each burner individually turning them to high. Are the burner flames higher than before? If so, you just solved your problem.
Remember to turn the tank ON very, very slowly after turning it off to change the tank or if you turn the tank off after each time you grill. Also, when grilling preheat the grill with the lid closed, after lighting the burners.
Hope that solved your problem ... Happy Grilling!
Feb 15, 2011 | Ducane Rottisserie 2004 (LP) All-in-One...
My 1100lp when burners are on low flame is to low and make squeeking noise and if a slight bit of wind will blow out flame. I cleaned burner tubes and replaced regulator with factory parts will heat up on...
turn off the LP Tank, disconnect the hose from the tank and wait 5 minutes. Reconnect the hose and turn the tanl valve on very, very slowly, until it's fully open. Light each burner and turn it to high. Wait for the burners to heat up and turn them down gradually to low. If flame height on low has returned to normal, the problem is solved.
If that didn't solve the problem, the air shutters on each burner may need adjusting. Consult the installation instructions that came with the new burners for the proper setting or consult your Owners Manual.
If it's real real cold outside, it's not unusual for the burners set on low to have a problem. The only solution to that is let the grill preheat well, before turning the burners down. Also, grill with the hood closed on low, if it's a windy day.
Hope this helps you and gets you back to grilling again.
Feb 11, 2011 | Weber Genesis Silver A Grill
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Thermos Stainless Steel Gas Grill Logo
77 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
