Technics Turntable SL 1200 M3D Damaged top case
This may seem like a crazy question because it basically just about the look. I purchased the above turntable used for my late teenage son who wants to give a shot at some small DJ engagments. The turntable came damaged. The upper aluminum shell on one corner was scraped and gouged on 2 sides. I have been able to buff it smooth with some 500 grit sandpaper but need to fill in the gouges, reshaped the corner a little bit and hope to find some paint that is close to feather it in. Long story - and filing a freight claim may be more trouble than it is worth.
Any tips about fixing this before I start messing with this.
  • deeciple Mar 05, 2009
    Do the faceplates generally stick out much? Or are they pretty flush with the rubber base?
  • 515 Answers
Your on the right track, however, a simpler solution would be to just buy a Faceplate for the unit.
You can purchase FACEPLATES @ 1200s.com
Although these are for the SL1200MK2 series - they don't make them for the SL1200M3D - you will have to drill a hole about 3/4" next to the pitch control, to make room for pitch reset button.
Or, if you want some tips on fixing and sanding, check out the following FORUM.
- Davis
DIGITAL ANALOG THERAPY
www.REPAIRNYC.com
DJ PRO AUDIO
Posted on Jul 15, 2008
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Feb 03, 2011 | Technics SL-1200 Turntable
I have a technics 1200 mk5 and when i put a record on the volume is low no matter how high i pt it up in the mixer. When i use it with serato it works fine. What can be the problem?
Years ago, Radio Shack sold a turntable with the same problem. The fix was to purchase a pre-amp to go between the turntable and the tuner/amp. I think this had something to do with a magnetic vs. ceramic cartridge?
Dec 14, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
May 10, 2010 | Technics SL-1200 Turntable
There is not a signal going from the turntable (technics 1200 m3d) to serato on my computer. when I analayze it there is nothing
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Jan 16, 2010 | Technics SL-1200M3D Turntable
TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
Apr 08, 2008 | Technics SL-1200 Turntable
752 people viewed this question
 Grubhead
Grubhead
