Question about Honeywell EFY041 Tower Fan
The fan does not oscillate and it is a Honeywell HY-013 not the one above
I have removed the stand from the bottom and when the fan is without the base it will oscillate I placed the stand back on and then it would not. Is there some wrong with the arm (shaped like a boomarang) is it supposed to face out or in
  • 7 Answers
SOURCE: Cleaning a HOneywell 14F0 fan
Norm I have this fan & have removed those screws.   Look directly above the switch on the back of the fan, let your eye travel up to the extreme outside edge. Such as where you'd find 12 o'clock on a timepiece.   The screws are very small.  About the size of the head of a finishing nail.
Follow the edge around to 2 o'clock, 4 o'clock, and so on.  Don't blink.
I used a very small philips head screwdriver, the same size as for doing watch or eyeglass repair.  Remember to have a secure place to put the screws, such as a pill bottle, or lid.
And the screws can be difficult to remove, apply a lot of force downward on the screwdriver and turn s-l-o-w-l-y.  Don't strip the head of the screw.
Good luck, Liz/Bizzie Lizzie Atlanta
Posted on Jun 16, 2009
  • 10865 Answers
SOURCE: Can you by smallparts for the tower fan...I have a
hello. Go to the source at honeywell. http://www.honeywellparts.com/?gclid=CKnxm8i44aICFcl25Qod7TEJxw
J.
Posted on Jul 10, 2010
SOURCE: User manual for my fan???
I have the whole manual, but couldn't find the digital copy available either on the honeywell site.
Posted on Jul 27, 2010
ftw1952
  • 10319 Answers
SOURCE: I have a Honeywell 16"
remove the battery from the remote for one day. See if it stays off. If it does replace the remote
Posted on Aug 31, 2010
bayyagg
  • 1672 Answers
SOURCE: i have a honeywell upright
The problem would be the burn out thermistor(FUSE), it is located in the winding of the motor itself. Before that check the wiring connection in the speed switch, the main line might have cut off.
Using the tester, check the continuity of the fuse. You can't see the fuse, it is mainly covered and connected in the capacitor line.
The cause of the burned fuse is overheating, the shaft bushing needs oil or have to be replace!
Hope that helps you out!
Posted on Jun 09, 2011
Honeywell hy 013 making noise while osillating
You can replace the control arm screw with a longer one of the same diameter and thread pattern.The longer screw will catch the base and allow proper oscillation motor to catch the base.
Jul 23, 2016 | Honeywell Dryers
Hy108tgt
Our HY-108 (not a HY-108TGT) does not have a filter when it was purchased new from a Retailer.
IMHO, Honeywell/KAZ designed these Tower Fans to be disposable if they fail to work or need cleaning.
These Fans are hard to disassemble for service or maintenance, OEM replacement Parts are unavailable to the general public, service documentation is hard to find, and the Tower Fans tend to have a short Product lifespan. THEY BREAK EASILY! The OEM Service Manual points to replacing complete parts assemblies because few electronics diagnostics and no schematics are provided.
The HY-108 case can start to be disassembled (I have done so on ours) by *First* removing the screws and separating/removing the plastic Base from the main Case assembly. *Second* remove the Phillips-Head screws on the back of the Case. *Third*, the internal plastic 6 Tabs that keep the 2 halves held together need to be gently separated - careful, they break easily. You need to gently loosen the internal plastic "Tabs" by using a thin flat-head screwdriver to gently and carefully separate the outer shell cover.
Apr 19, 2014 | Honeywell Dryers
Honeywell HY-108 fuse
is imple you must take out the cover and see if the fuse is glass or ceramica unplugged the device from wall. and the same type of fuse, voltage, and amperios, YOU CAN NOT PUT MORE OR LESS ONLY EXACTLY. Otherwise you will have burning.
God bless you
Aug 02, 2012 | Honeywell HY-108 8-Level 32 inch QuietSet...
Where is the fuse on a honeywell quiteset hy-108
KAZ Inc. has franchised the use of Honeywell's company name to manufacture/market this KAZ OEM HY-108 Tower Fan. The small 2.5A fuse you are looking for is located inside the 2-Prong Electrical Outlet Plug. This tiny 2.5A Fuse can be hard to find as a replacement in retail Hardware Stores, but see if you have an old LONG string of indoor/outdoor Christmas Lights... some of these Christmas Lights Strings may have the correct 2.5A Fuse you need. IMHO, it's strange that KAZ Inc. did not put instructions in the Honeywell HY-108 Owner's Manual where the Fuse is located!
May 31, 2012 | Honeywell Hy108 Tower Fan
Honeywell Fan
to rule out an overheat condition, if you immediately try again, does the exact sequence repeat, and again repeat...how many times without change in "only run momentarily" time? if the time "only run momentarily" never changes, then overheat is not the problem. so look for a faulty timer function that repeatedly times out. try changing timer settings.
May 30, 2007 | Honeywell HS400 Stand (Pedestal) Fan
Honeywell EFY041 Tower Fan Logo
211 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
