Question about Whirlpool Duet GHW9150P Front Load Washer
If I replace my bellow seal in my front loader will it leak?
I Would like to know if I replace that grey seal will it leak?
  • shannon3 Jul 12, 2008
    This is a big help
  • 5,911 Answers
It will not leak if you install it correctly. Click on the following link for step-by-step instructions on how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Inspect the new bellow PRIOR to beginning installation. Make sure the inner clamp that attaches to the wash tub is snug and not overtight. Also, make sure the rubber on the bellow that fits over the dispenser tube in the door area is installed past the flange (raised area on the tube). These are the common points that leak. Please let me know if you need further assistance. I hope this helps you.
Posted on Jul 12, 2008
It appears that out washing machine is leaking from underneath. Is this possible? We have had it for 9 years. Is it time to get a new one?
Before assuming the washer needs replacing, please follow the advice in the following link to determine where the source of your leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most common sources of front loader leaks come from the door bellow (gray rubber seal). The rubber seal does wear out over time and may need to be replaced. The cost of a replacement bellow is far less expensive than replacing the entire washer. The last time I checked (I personally own a front loader), these washers are not cheap.
If you determine, the bellow needs replaced, the following link explains how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Another secondary cause can be a leaking drain pump. Make sure you also check all the interior drain hoses and fittings. If replacement parts are required, I have found great luck with the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The first three websites have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. Shop and compare. Prices vary between sites.
If you need further assistance, please let me know. I hope you find this information helpful.
Nov 03, 2011 | Kenmore Elite 45986 Front Load Washer
Tiny leak at front of machine
Is this a FRONT LOADER? Or, a TOP LOADER?
The following link explains how to access and inspect the interior of a FRONT LOADER and what common sources of leaks to look for:
The most common source of front loader leaks comes from the door bellow (gray rubber seal). A routine inspection around the perimeter of the door for rips or tears will tell if the bellow needs replaced. If the bellow requires replacement, the following link explains how:
If this is a TOP LOADER, the following link explains how to access and inspect the interior for common sources of leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The most common source of leaking on a TOP LOADER is the drain pump. These pumps are not serviceable and if found to be leaking, need to be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Whatever style washer you have, make sure you read through the links provided and follow the steps on how to properly access your washer interior so you can get an accurate view. Make sure you check all tub seals, dispenser hoses and drain hoses as well.
Replacement parts (if required) can be purchased from any of the following websites:
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jun 22, 2010 | Washing Machines
Washer is leaking from under machine checked all hoses and drain connections and there were no leaks in them.
repairclinic.com
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Jun 08, 2010 | Washing Machines
Water leaks from the front door. it leaks at the bottom of the door and puddles on the floor. Do I need a new gasket that seals the front door??
If you have a leaking FRONT LOADER, the following link explains how to access and inspect your washer for leaks:
In the majority of the cases with front loaders, the door bellow begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the links provided and make sure you inspect all the drain hoses, drain pump cover and tub seals as well.
If you have any questions, please post back and let me know. I hope you find this information helpful.
May 05, 2010 | Kenmore 46462 Front Load Washer
My washer leeks from the bottom, slow drips,when in progress. Can I fix this myself
If you have a leaking FRONT LOADER, you will need to remove the lower toe panel under the door and inspect the washer interior cabinet to sufficiently determine where the source of the leak may be coming from. The following link explains how to access and inspect your washer for leaks:
Make sure you throughly check all drain hoses, hose connections, the pump seal and the dispenser hose(s) that penetrate the door bellow.
These problems can easily be repaired without the assistance of a repairman. If you have any questions, please post back and let me know. I hope this helps you.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite he 3t is leaking water when the water fills up. I think from the bottom
Read through the link provided and let me know if have any questions. Please post back with your MODEL NUMBER so I can determine how your washer is specifically configured. I hope you find this information helpful.
Mar 27, 2010 | Washing Machines
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
My front loader washer is leaking at the door and it don't seem to get my clothes clean what do i do
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Although the bellow may not have any physical tears, they can also become mishapened over time due to normal wear and not seal properly. You should have a good tight seal all the way around the door.
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Some additional items to look for that may cause leaks around the bellow:
1. Check the dispenser tubes that pentrate the door bellow. Sometimes they get pushed behind the rubber causing the water to trickle behind the bellow and leak. You will notice this on fill and rinse.
2. Check the rear bellow clamp that holds the seal to the front facing of the wash tub. The clamp can come loose, causing it not to seal properly.
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW@ whirlpool Duet grey seal leaks
Here's the instructions you need to replace the door bellow on a Whirlpool Duet:
Let me know if you need further assistance. I hope this helps you.
PS I know it's a lengthy read, but it's a simple repair if you follow the directions.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
343 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
