Toshiba (PA3212U) Wireless Adapter Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Toshiba Satellite laptop has begun to lose connection to my wireless internet provide (Frontier). I log on and the machine automatically connects but every five or ten minutes, the signal weakens. My second computer, which is newer, doesn't lose the signal. That is the signal on the Lenovo machine remains at "excellent" - all bars - while the Toshiba drops to "limited accessiblity." I've reviewed the settings on the Toshibe to ensure they weren't changed from two months ago when the machine was working just fine. Settings seem to be right. Is it time for my Toshiba to get a new wireless adapter? Or is this a problem that may just require a little tweaking . . .?
Anonymous
Level 3:
  • Master 506 Answers
  • Posted on Jan 10, 2011
Anonymous
Master
Level 3:
Answers
506
Questions
Helped
119827
Points
1487
You may need to replace the netwok adapter on Toshiba Laptop to get the wirless working properly again.
  • Anonymous May 21, 2013
    I have the same issue but it only happens at school and no one else has a problem. I am just fine at home or anywhere else, it is just school.
Toshiba Satellite M45 WinXP keeps dropping wireless internet connection.
Try to do update from Control Panel - Security Center - Automatic update.
My Toshiba Satellite Pro U400 has stopped connecting to the internet. Connectivity docotr says IP address needs to be set/was not set properly. Not my internet connection because other computer in the...
Your Toshiba Satellite Pro might be using a specified IP address. Try to set it to obtain an IP automatically. Depending on the Windows OS, whether it is XP, Vista or Windows 7, go to your Control Panel then Network connections or Network Sharing Center and double click on the Local Area Network connection (if your are using wired) or Wireless Connection. Look for the TCP/IP protocol and make sure it is enabled as "Obtain IP address Automatically" and "Obtain DNS addresses automatically". Then click OK to save settings.
Should you need further assistance, please let me know. Thank you for using FixYa.
My toshiba laptop Satellite L25-S1194 wont connect to the internet. other laptops is able to connect.When viewing wireless network settings, I can see the laptop is receiving the signal, but unable to...
Is this the first time you are trying to connect to your Internet with that Toshiba laptop?
If that is your first time you need to call first your Internet Service Provider and check what can they do for you.
If there is no problem with you Internet Service Provider, try to press the FN+F8 keys these are the toggle keys to enable or disable your Wifi.
When you press those two keys observe the laptop if you will have a message that says Wireless Connection is On or Off. If it is off, try to press those two keys again to turn on the laptop.
I believe your laptop came with a Wireless On/Off switch, check that also if it is on there will be a light indicator for the Wireless Connection. It should be a steady light.
Now, if the wireless connection of your laptop is on and still you can't connect to your wireless connection, try to update the drivers for your Network Adapter.
Here's the link for the latest driver:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1124513&rpn=PSL2XU&modelFilter=L25-S1194&selCategory=3&selFamily=1073768663
You need to search for your operating system and choose the Wi-fi on all categories.
You need to save it first on the laptop and after that you will have an option to run it on the laptop. After the installation of new driver try to restart the laptop and try to connect to your Internet.
If that will not work.
You need to contact Toshiba technical support at
Toshiba Technical Support
800-247-7777
Hope this helps. :-)
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
2answers
Toshiba Satellite L355D wont connect to the wireless internet
i am having the same problem and its not software related as i have my laptop dual booting with sabayon 5.0 and im getting the same result in that OS so this tells me that the hardware is failing
if your problem is the same as mine have you exposed your computer to cold or humid atmosphere?
mine sat in my trunk for a week this newyears
1helpful
Laptop wireless connection
assuming you have set up the router to enable DHCP which automatically detects pc's and assigns an automatic ip address, and assuming you are using XP and not Vista, although the workthrough is similair; go to open internet explorer>tools>internet options>connections tab and ensure that never dial a connection is ticked, then apply and exit IE
Next go to control panel>network connections, double click your wireless connection icon, select the TCP/IP line and click properties, then make sure obtain an ip address automatically is ticked, apply it ok, then open IE again and click the refresh button a few times.
Keep losing internet connection
Recommendation: If you can switch from the 3rd party wireless utility to the Windows utility. There should be a check box under the properties that says, "Let Windows manage my connection." Also turn off any power management that stops your drives, suspends the machine, etc. When doing WEP, use the actual key, not your password. i.e. the one that looks like "aaff996753bc" not "rosebud".
Reason: Windows wireless starts before you even log in and loads as a service, it runs whether your logged in or not, sleep mode, etc. 3rd party utilities...especially my personal bane of all wireless devices "Netgear" load as applications. That means they don't initialize until after log in and they can be suspended completely or prioritized by power management and resource management utilities when the machine is idle. As for the key thing... WEP translation with Linksys especially can be a little funny with some wireless so I use the key itself which always works.
Internet
Username and password available from your Internet service provider. Security key configurable on wireless network properties.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
