Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore he3 My machine is making a lot, and I mean a lot of noise. It will not spin, and the clothes are soapy and still drippng wet. Does anyone know what the probelm could be?
  • scraks May 11, 2010
    How do you know how much soap to put in it
The Belt in the back has come off. I am dealing with the same issue now.
Posted on Jul 31, 2008
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
My washer is making a lot of noise when spinning. What can it be?
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 26, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite HE3 Tearing holes in my clothes
Are you using HE ( high efficiency ) detergent?
If you are using regular detergent the machine may be sensing all those bubbles and may be working longer to get rid of them.
Try using a net/lingerie bag for delicate clothes.
This type of washing machine works by sensing when the clothes are saturated then it will start to tumble back and forth, and it will continually drain out the dirty soapy water and bring in clean soapy water, then spin out and go into the rinse cycle..
It's all done by the machine sensing when it's time to go to the next cycle.
I am wondering if you are maybe using too much detergent.. Only use the max of 3 tablespoons of HE detergent if you have hard water and 1 tablespoon if you have soft water.
Hope this helps.
Sep 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
No spin cycle
have you tried unblocking the inlet and outlet pipes under the drum
Apr 25, 2009 | Whirlpool AWM6120 Front Load Washer
Kenmore HE3 CONTROLS LOCKED
Apparently there is a child lock on the machine and by holding down the spin and drain button for 3 to 5 sec. this will unlock the controls
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
My HE3 washer, about 4 yrs old is locked , showed error code 6
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the control is unable to properly detect motor speed. Due to this the machine shut itself down.
Nov 11, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
HE3 washer not drying the cloths
I had this problem a few months ago and it turned out to be a bad water pump; I replaced it myself and it was incredibly easy. The hardest part was removing the front panel, below the door because the screws are under a lip, about half an inch off the ground. When you get it off, the pump mechanism will be right in front of you. The pump is on the right side of the mechanism and is screwed into the plastic part. When I removed it, the impeller (a small, ribbed plastic part that spins and moves the water) was broken off from the motor. You can buy the whole pump mechanism from Sears for about $100 and install it yourself. Just follow the directions that come with it!!! Hope this helps.
Jun 10, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Robert Rankin
