Question about Belkin (F6C800-UNV-PL) UPS System
UPS Hi my UPS is not working correctly I only have one LED green light on. WHen I try to test it shuts off what do I need to do?
  • marktinker Feb 10, 2009
    800va belkin ups works on straight through power not on battery backup. If test/power button if pressed for short time causes orange battery light to flash once for very short time and ups switches off. have checked batteries with volt meter and both read 12,67ish and 25v ish together and are showing higher charging voltage when ups connected to mains. bat connections seem good mark
    Genius:
  • 1,198 Answers
Unplug it and open it up. Check the batteries with a load tester of the same voltage, like a car lite bulb. If the batteries are good, check that the connectors are tight on their fittings. I had to squeeze the ends on my Cyberpower unit with a pliers to make it tight enough to work right. If the batteries are dead and you can't charge them, contact BatteryBob.com, he gave me good service.
Posted on Jul 15, 2008
APC SUA1500RMI2U Smart-UPS . the led blink with red after the test button . it is indicated with cross. continuously blinking & no green indication shown . but ups is running
Hi Juhi,
You may need to replace your batteries. Have you checked battery voltages?
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 07, 2014 | APC (SUA1500RMI2U) (0731304197300) UPS...
No output
You should start with Rotary switch on "Maintenance Bypass" position and Qf1 open.
Turn Rotary Sw to "Test" position and wait for self test to execute and UPS to turn on.
Once you get the Yellow lamp lit, it is asking for QF1 to close
Once closng QF1, if green LED is lit, turn UPS off by pressing gray button until it ask for confirmation, select Yes and press Return.
Turn Rotary Sw to Normal position, press On button and the green LED will illuminate.
If, after closing QF1, the green LED didn`t lit, turn Rotary Sw to Normal, press On button and wait for green LED to lit.
Thats`it...
if anything is not working well.. please let me know.
Mar 25, 2014 | MGE UPS Galaxy 3000 UPS System
Power light flashing green to red
Assuming the "squiggle line" is the Utility LED the unit has proper power. The light is steady green and not flashing, correct?
Have you reset the unit?
Try removing all but one attached device to verify it's not an overload condition.
A photo of the control panel would help.
Dec 23, 2012 | HP Compaq T1500 XR (204203003) UPS System
Internal problem galaxy 3000 ups
The question is not clear... which of the LED`s are lit?? green, yellow, red.is there a message on the screen??
May 18, 2012 | MGE UPS Galaxy 3000 UPS System
UPS for LED tv
The set need a UPS with minimum 500W load capacity
Apr 02, 2012 | Sony 55 KDL55EX720 3D LCD TV
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
I can't tell if the battery needs to be replaced in our Belkin 900. Should the green indicator on the front be completely lit up? Only one seems to be.
Link to manual:
http://cache-www.belkin.com/support/dl/f6c900.1100unv.pdf
Turn on your UPS by pressing and holding the On/Off/Test
button for approximately 2 seconds until the “ON LINE” Green LED
comes on. Pushing the On button less than 2 seconds is a test function.
Simple test: plug a light into one of the battery backup outlets. Then unplug unit. If the light stays on then it's working and the battery is ok.
Mar 02, 2010 | IBM Belkin Enterprise 900VA (31P7076) UPS...
Smart UPS 1500 - battery level green lights blink on and off
You need to run recalibration on the unit.  The supplied PowerChute software & cable will allow you to do this if you hook the UPS up to a PC (I know it works with the serial cable, not sure about USB).  If you only have a MAC then I cannot offer a solution other than to buy the standalone PowerView device from APC.  It will cost a bit more than a battery, but may save you from buying needless batteries in the future.  I finally broke down an bought one, but note that I was still having the problem after the 1st recalibration.  By trial and error (and maybe a vague memory) I put my MAC in sleep mode, that dropped the load to stop the lights from flashing.  Then I recalibrated with a 22% load and now it finally seems better (lights no longer flashing).  This was with a Smart-UPS 1000.
Let me know if that helps.
Apr 01, 2009 | APC Smart-UPS 1000VA UPS System
Belkin UPS F6C800 Problem
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Shutdown of UPS whenever there is a Power Surge. I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
I see that you are using
Generally, the issue happens if you are not using the UPS as per Manufacturer specifications or if it is overloaded frequently then UPS  shutdowns
To isolate the issue, I recommend you to check and go through below information.
If you see ON BATTERY a Yellow LED OR Flashing Yellow
LED with Audible Alarm (Beeping) then it means this condition for the On-Battery LED can indicate 1of 2 problems: They are:
1. The UPS is on battery backup and an intermittent audible alarm is on. The UPS will begin shutdown procedure.
2. Battery is low. The UPS will sta rt shut down. The buzzer sounds an audible alarm .
if you see a Solid Red on your UPS , then it means that UPS is either fault or overload.  It happens if there is a issue with UPS. The LED will be lit continuously and the unit will sound an audiable alarm for 10 seconds. Other cause could be with Battery is weak or Bad, the Battery needs to be replaced under this condition.
If you use a Flashing Red LED, then it means that battery is trying to give more power than it should. It happens then UPS is overloaded.
Let me tell you,,,,
Only data sensitive equipment such as a computer, monitor and external drive should be plugged into these outlets. Battery power is automatically
provided in case of a power outage. Power (AC or battery) is not supplied to these outlets when the UPS is switched off. (Do not plug surge protectors or power strips into the battery back up outlets).
 Most Important factor that effects the issue is that,
Caution: Never connect a laser printer or scanner to the backup outlets of UPS with other computer equipment. A laser printer or scanner draws significantly more power when in use than when idle. This may overload the UPS.
And caused the UPS to shutdown whenever there is Power Surge
To isolate the issue further, let me tell you the way where you can test the UPS if it is fine or not.
1. Charge the UPS for around 4 hours, and try below steps.
To Conduct a Self Test
Use the self-test to verify both the operation of the UPS and the condition of the battery. In normal utility power, push the On/Off/Test
button less than 2 seconds and the UPS performs a self-test function. During the self-test, the UPS operates in back-up mode.
Note! During the self-test, the UPS briefly operates on- battery backup power (the on-battery LED comes on). If the UPS passes
the self -test, it returns to on-line operation. If the UPS fails the self-test, it immediately returns to on-line operation and lights the replace battery LED. The loads are not affected. Recharge the battery overnight and perform the self- test again. If the replace battery LED is still on, the battery will need to replaced.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 28, 2007 | Belkin (F6C800-UNV-PL) UPS System
Belkin (F6C800-UNV-PL) UPS System Logo
257 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
