Siren went off would'nt shut off. 5years old. changed batteries in box and motion sensor. connections were a little coroded cleaned them. I enter access code says it is invalid. Put in 1234 same thing. Buttons do not seem to work. I was thinking of replacing unit. Help.
Thank you,
Rick
have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when...
(More)
have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when checking system status still saying low battery,
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it...
(More)
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it back up the alarm sounds and the code number will not stop it.How do I remedy this?Thanks.
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
