Question about Maytag MSD2756G Side by Side Refrigerator
Only lights and water dispenser are working on Maytag MSD2756DEW
Original problem was fridge side not cold enough. In the last couple weeks, it would stop cooling both fridge and freezer all together. I would bang on the upper right side with my fist and than it would kick back on. Following suggestions on this forum I replaced the Adaptive Defrost Control board, part #61005988. Now the only things that work are the interior lights and the water dispenser. No fan, no compressor. No cooling what so ever. Everything else is in melt down. Neither the old or new ADC board make a difference. I left it plugged in over night hoping it was just going through a defrost cycle or something and might wake up to it just chilling away, but no such luck. Could something have affected the white plastic overload relay located on the side of the compressor. The original part number I have for that is 4SP1034. But after researching this I find that it has been "upgraded" to something that looks very different and comes in a "kit" with several pieces to it instead of one, around $50. I've also found part #10377015 that looks like it is something internal to the overload/relay part and is much cheaper. Then I find other parts that look similar to the internal part but with many different part numbers. Apparently there are 2 parts internal to this original white piece, the relay and the overload. Anyway, would a defective over load switch cause my current problems? Please help! I'm very disappointed in this Maytag product. It seems they just don't make them like the used to. The Maytag repairman is in hiding these day. Oh, and on top of this, my water heater is going out too.
Thank you all, Vivian.
  • 1 more comment
  • bluesmoke59 Jul 13, 2008
    Inside the white plastic box 4SP1034 is the overload switch and the relay. Both pieces actually look fine physically. The relay is not a bi-metal part like the pic you sent. It is a positive temperature coefficient thermisor. Out of circuit, I measure 5.7 ohms across the thermistor/relay at ambient temperature. On the overload switch, I measure .7 ohms ( almost no resistance) between the spade that the blue wire clips to and the channel on the switch that acts as the jack to the center post on the compressor. Are these acurate measurements? I would like to know by troubleshooting/testing if the parts are bad, rather than spending $50-60 and waiting for it to arrive, and then still possibly having the same problems. What has me questioning this is the fact that condensor fan is not running. Looking at the schematic, I can see where this overload/relay combo part would effect the compressor, but why the fan as well?
    I would like to narrow down what is actually wrong with my fridge. After replacing the Adaptive Defrost board, the fridge was worse. I don't want to "buy and try" different parts as a troubleshooting method. Thanks for any help, Vivian.
    Please understand that I am not a refrigerator technician. I am someone who worked in tv and stereo repair in the past and have a fundamental knowledge of schematics and can use a multimeter. That said, again my problems really started after replacing the ADC. Before that all was fine except the fridge portion not quite as cold as it should be. I haven't gone any further at this point than starting with the schemtic, researching this forum, and using that information to pull and check the overload/relay. Those internal overload/relay parts are available separately should one or the other or both be bad. I would like to no how those are suppose to read/test before tearing the back off my freezer.
    Scholar:
  • 148 Answers
Overload switch for sure,stops the fridge once you replace that,if it doesnt defrost change the bi-metal
Posted on Jul 13, 2008
  • 2,335 Answers
You can click here to find more ways to troubleshoot your appliance.
MZD2766 fridge light works but the fridge and freezer is not working. The water dispenser and ice cube not working either. I did hear buzzing coming from inside the top fridge side occassionally.
it could be a defective cold control,you can use a jumper wire to bypass this and see if the compressor starts,or it could be a bad ptc overload on the compressor itself,and these are easily changed too
May 23, 2010 | Maytag MZD2766GES Side by Side...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a LG LRSC 26923 frig. It will make and dispense ice fine. We cannot get water to come through the dispenser. We had this problem a couple weeks ago and it looked like water had frozen up in the...
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
Aug 26, 2009 | LG LRSC-26922 Side by Side Refrigerator
Whirlpool water dispenser
IS THE FRIDGE OMPARTMENT COLD ENOUGH AS THE TANK THAT HOLDS THE WATER IS LOCATED IN THE FRIDGE COMPARTMENT.PLEASE FEEL FREE TO ASK MORE ADVICE.MOHAMED
Jul 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
402 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
