2003 Chrysler 300M Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change thermostat and where is the location
Spyro Matiatos
Level 2:
Sergeant:
  • Expert 210 Answers
  • Posted on Jan 10, 2011
Spyro Matiatos
Expert
Level 2:
Sergeant:
Answers
210
Questions
0
Helped
71702
Points
554
Remove the coolant cap to relieve the pressure. Follow the radiator hose to the motor. The metalic/aluminum part that the hose is connected to holds the thermostat. 2 or 3 bolts hold it to the engine. remove these bolts & the thermostat. there may or may not be a gaket with your model. If so, replace them both. You will lose some coolant. add coolant when you're done, Make sure the engine is cold when u do all this.
Anonymous
Level 2:
Sergeant:
  • Expert 157 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
157
Questions
0
Helped
107155
Points
532
Unlike most cars where the thermostat is on top of engine. The 300 has its thermostat at the bottom of the engine. follow the lower radiator hose from the radiator back to the engine block. It is hooked to the thermostat housing, and of course, the thermostat is just under the housing.
About changing or replacing the thermostat, it is very difficult to perform and requires an technician's expertise with a reasonable amount of time say, 3 to 5 hours. I'd advise you to take the vehicle to an auto shop for efficient and adequate replacement.
Best of luck.
How to replace thermostat in 1999 volvo
Don't just change just the thermostat... change the sensor located in the thermostat housing (if your engine is overheating). The whole works is located inside the timing cover. Sockets: You'll need a 10mm for the timing cover and the 3 bolts on the thermostat cover, and an 8mm for the sensor harness bolts. Then you'll need a 3/4 open end wrench for the sensor.
How to change thermostat on 2001 rav4
  • The thermostat on a Toyota RAV4 is located inside the engine coolant container. To reach the thermostat, open your hood and locate the coolant filler cap. Open the cap and then drain enough coolant so that the coolant level is below the thermostat housing. You should be able to identify the thermostat as a circular cap attached to the inside of the coolant container
How do i change thermostat
See picture below, thermostat is located on driver's side of engine. You will have to remove the alternator to get proper access to the thermostat.
2helpful
How to change a thermostat
Hi.
  1. Locate the thermostat housing. The housing can be found following the radiator hose toward the engine. The housing is located on the engine.
  2. Remove the three screws that hold the thermostat housing.
  3. Replace the thermostat.
Note. The thermostat spring goes toward the engine, the other side toward the radiator.
Here a diagram:
Regards.
Ginko
1helpful
I need to changethe thermostat! where is it
i find the best way to locate a thermostat on any car is to locate the top hose from the radiator and follow that to the engine when you get to the engine, where it connects to should be where the thermostat is housed...hope this helped
I need to know the location of the Thermostat on my 1996 Jeep Grand Cherokee,
If you have a V8 the thermostat is located under the coolant inlet tube. The tube is located on top of the engine, in the front about center. The thermostat is hard to change. Locate the upper radiator hose on your radiator and follow it to the engine block it is located on the top front part of your engine and you must lean over the front and look down onto the block to see the thermostat housing.
1helpful
Where do i locate the thermostat on my 94 scoupe?
Follow top radiator hose and it will lead directly to thermostat housing. Housing should have 3 bolts on it. Thermostat is under it.
13helpful
3answers
Thermostat location 1995 jeep grand cher. straight 6
Thermostat is located on 4.0L I-6 on front cylinder head. The 3.7L V-6 thermostat is located where the lower radiator hose attaches to engine. The 4.7L V-8 thermostat is located where the lower radiator hose attaches to engine. The 5.7L V-8 thermostat is located where the upper radiator hose attaches to engine. The 3.9L V-6 and 5.9L V-8 Thermostat is located on front top of intake manfold (between alternator and ac compressor)
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
