Switch to Wireless
Good morning,
I am trying to figure out how to switch back to wireless when I need to
  • harose362 Jan 02, 2009
    where is the wireless switch
  • 72 Answers
Wireless radio switch vary with make and model of the machine. The total list of all takes several pages, try posting your model(s) and you will get a better set of answers.
Posted on Nov 22, 2009
At the side of your laptop there is a wireless switch, once you turn it on the wifi light turns blue(I think); and if it is off it turns in yellow or orange... And there are different wireless switch... what is your computer so that i can tell you where the wireless switch is
Posted on Jan 19, 2009
    President:
  • 778 Answers
Basically you could right click on the wireless icon in your systray (to the left of your clock usually) and select "View available networks" then click the "Refresh list" in the window that comes up and select the wireless network you want to connect to and then click the connect button at the bottom right corner of that same window. That should do it.
Posted on Jul 15, 2008
Wireless Switch Broken
here it is -
http://www.manualowl.com/m/Gateway%20Computers/T-1625/Manual/147650
enjoy!
Nov 14, 2012 | Gateway T-1625 Notebook
Wireless switch is broken cannot turn on wireless adapter
Dear Friend,
If the wireless switch broke, you might need a flash light and something very thin and long to turn it back on. Now, if the switch attached to the motherboard broke as well you need to think about getting another motherboard.
You might want to consider and external USB or PCDM wireless card if you cannot turn it on.
Good Luck!
Jan 02, 2012 | Acer Extensa 5620 Notebook PC
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
I have a gateway m6752 laptop with a wireless mechanical on/off switch on the left side. I turned it off and back on one time and now I cannot get any wireless reception. The wireless light is on, but no...
if the laptop shows that the wireless is on
then click on the system tray on the wireless icon and a screen will pop up showing wats the atatus , may be then u can be cleared to wats up
good day
Jun 01, 2010 | Computers & Internet
How can I turn on the wireless capability on my Asus G60VX laptop? the switch on the front left is on and still nothing. trouble shooting says wireless capability is turned off. it was working fine untill...
I can figure out that your laptop runs Windows Vista. Go to Control panel, then Network and Sharing centre and then go to Manage Network Connections and see if the Wireless Network Connections icon is disabled, make sure it is enabled and not connected. Try disabling and enabling it again. If still no go, try to manually turn off the wireless switch and turn it back ON. Check the light status (if any), confirm the error message too. If still, it seems not to be working, then the internal switching might have gone bad. You need to get the laptop serviced.
Regards,
Arvind
May 25, 2010 | ASUS Operating Frequency 2.4 - 2.5 GHz...
On my e5500 it does not see wireless networks this morning
Hi, there is a wireless toggle switch on the side of your laptop. It slides back and forth to turn your wireless card on and off. It has a little wireless symbol next to it, and you should NOT see red. If you see red showing, it means that the wireless adapter is turned off. Slide the adapter to the ON position, and then try to repair your wireless connection. Hope this helps!
Mar 08, 2010 | Dell Latitude E5500 Laptop
I have wired access but no wireless access. It worked this morning after no wireless for a while, but this afternoon nada desite mutiple reboots.
Is the wireless LED lit up. If it is then, scan for the wireless and try to reconnect to the wireless.
Also make sure if your wireless switch of the laptop is turned ON !!!!
Oct 10, 2009 | NetGear WGR614 Router
Wireless
hello..can u see the switch side on the unit.?theirs a switch on wireless..or if the switch are on,and their is no happen,you need to run and configure the wireless lan to internet connection.try to double lift click the wireless lan then auto run to find the wireless connections..Thanks and Good Luck..^_^..Have a nice day..^_^
May 14, 2009 | Acer Aspire 5315 Notebook
TOSHIBA EQUIUM WIRELESS PROBLEM
You might deleted your driver to wireless connection or you perhaps upgraded Service Pack to higher version. If your wireless connection will work on lower SP then that device won't work or vice versa.
Another thing, try to check connections. Click menu and look for connections and try to enable wireless connections.
Thanks
Jan 11, 2009 | Computers & Internet
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
852 people viewed this question
David Payne
David Payne
