Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Radio disabled and cannot enable
About the Pavilion zv5000 (2004 or 2005), the wireless network connection icon says the radio is disabled, but there is no switch visible to switch on and no access through windows network connections etc... This computer is using the broadcom device with that little red icon that looks like a radio wave.. I cannot enable through there or through the WLAN connection menu in the set-up... Any ideas?
Of course, I finally located the switch. It's more of a "button", and when it's turned off it is barely visible. Anyway, the radio button is right at the top center of the keyboard above the function keys. When it is on, it is lit up blue. When it is off, you may not even know it's there!
Posted on Jul 13, 2008
Elonex LNX/NB/ONEt/N5008PNK I HAVE THIS NETBOOK BUT CANNOT CONNECT TO THE INTERNET?
make sure the wireless is enabled (check for a switch on the edges of the computer, or the fn + f1-12 keys for a radio icon) then check your network connections in control panel to make sure your wireless is not disabled in windows then try to connect to the network
Jun 14, 2011 | Computers & Internet
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
Dec 20, 2010 | Computers & Internet
Wireless lan disabled. where is button to enable
for windows XP - go to control panel - network connection - eneble wireless LAN
for windows vista - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
for windows 7 - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
Mar 28, 2010 | HP Pavilion dv5tse Notebook
I was online when I ''lost'' my internet connection. When I run the cursor over the broadcom symbol, the message says''network 2 radio disabled''
I think you have a wireless enable/disable switch, the rightmost in the row above your keyboard, you must have accidentally pressed it. Press it again to turn the wireless network card on, it should come up and connect in a couple of moments.
Oct 30, 2009 | HP Pavilion ze2000 Notebook
IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Oct 07, 2009 | IBM ThinkPad R30 2656 Notebook
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
Lenovo x60 wireless problem
  • Check for association to an Access Point.
    Note:
Feb 29, 2008 | Lenovo ThinkPad X60 Tablet PC
Acer 5020 laptop wireless switch
you can go to network connections in control panel, then right click on the wireless adapter icon and select connect or enable.
Oct 07, 2007 | Acer Aspire 5100 Notebook
Radio on network adaptor disabled
look on your taskbar for 2 little screens with a red ross, right click and click enable or go to start>connect to>show all connections, then right click on your wireless connection and click enable.
Feb 18, 2007 | Broadcom BCM94306MP - IEEE 802.11b/g...
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
551 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
