Question about Whirlpool Microwave Ovens
My whirlpool microwave heats up the top cover / outer metal casing. It seems to get hotter and hotter, even though the food inside may not be all that hot. Eventually it may even stop running the magnetron. Thing is, it is clean, has airflow out the back, and did this more or less from new. So it works, but doesn't heat as quickly as many others I have seen, and seems to soak some microwave energy into the casing. Any ideas?
  • kim4468 Jul 13, 2008
    Hi, thanks for the quick response.
    It is not a cooling fan issue - that is running. I will do the heating test once I have a thermometer. Interesting thing to me is that the microwave definitely heats itself (i.e. outer casing) while it cooks. It is not a simple heat flow from hot food to casing, as it gets hot on top only. It has a grill, which I don't use, and isn't on, but could it be food-spatter / carbon in that area that absorbs microwave energy? I will continue investigating.
    Thanks again.
  • Whirlpool Master
  • 9,086 Answers
If the cooling fan is not running, then that definitely needs to be addressed to prevent magnetron damage.
-.htmThere should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
-.htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It might be useful to first do a standard heat test.
-.htmMICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or 70 if you're using a centigrade thermometer.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
The inside light bulb that works when the door opens and food is cooking is burned out, I have the new bulb but don't know where to replace it.
Brand and model would help but I'll guess at this. If micro is a wall hung unit over the range, you usually need to remove the top grill assembly above the door. Then look inside directly above the area where the bulb is located. You should see a metal cover with usually 1 screw in it to remove. Once screw is out that metal plate usually pulls forward and upward to reveal the bulb and socket. Replace bulb and reverse procedure to assemble.
If the micro is a counter top model---the complete outer case usually needs removed if you don't see a small access door by the bulb. Remove all screws around back edge and any screws in the side panels---then lift back edge and pull outer case rearward to remove.
Jun 03, 2015 | Microwave Ovens
It wont heat up my food
Hello there and thank you for choosing fixya
Whenever a microwave will not heat up food this is normally due to a failure of 1 of 3 things
First is the mengatron Magnetrons are made of magnets that conduct an electrical circuit, thus creating the energy needed to cook food in the microwave. Although magnetrons are durable, they will eventually begin to fail. If a microwave begins to lose the capacity to heat, the problem is most likely the magnetron. Testing the voltage in the magnetron is done using a device called an ohmmeter it is tested like this
Unplug the microwave from the wall and turn it around so that you are facing the back of it.Remove the screws in the back cover and the sides then remove the outer shell it should slide back a bit then up and off
Locate the high-voltage capacitor, an oval-shaped cylinder, and place the tip of an insulated screwdriver on top of one of the metal terminals protruding from the top of it. Tilt the other end of the screwdriver downward slightly until the metal part touches the other metal terminal. You may hear a popping or crackling sound, which is energy being discharged. Remove the screwdriver from the terminals.
Place the tip of screwdriver back onto the first terminal and tilt the other end of the screwdriver until the metal touches the metal base that the capacitor sits on. Hold for a few seconds, during which time you may hear a popping sound. Repeat the procedure with the other terminal. i will finish this in a second post
May 17, 2011 | Sanyo EMS2298R Microwave Oven
MH1160 Whirlpool Microwave Stopped Heating
Are you getting 110VAC on the primary leads of the high voltage transformer when you press "Start" to begin cooking?
If not, yhen it may simply be a bad cook relay (I do board repair) or a bad bottom or inside top door switch. See http://www.microwavecontrol.com/doorsw.htm
E-mail me via my site for more free help.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 21, 2017 | Whirlpool MH1160XSS Stainless Steel 950...
Lightning show in my microwave.
hi,the magetron is what heats the food...it has gone bad...or you have a burn mark on the cavity were you ,put the food in to heat up....please check the cavity first...next it will need to replace the magetron...hope this helps....
Nov 04, 2009 | Whirlpool MH7155XM Microwave Oven
Microwave will not heat food.
Sometimes inside the machine there is a fuse for this, if you can remove the outer case you should be able to see it, HOWEVER let me tell you that i have been in this position and have replaced the fuse and the machine then works only to die again, once this happens it is usally a sign that either the tube or a transformer is gone and it normally isnt worth getting fixed.
Mar 26, 2009 | Microwave Ovens
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
Mar 15, 2017 | Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
