Red and blue halo around objects - Televison & Video
  • crocks487 Dec 07, 2008
    I was playing a video game yesterday and all the sudden my picture changed from a perfect picture to a picture with a red halo over every object. It is a mitsubishi HDTV 1080- ws-55511. If you have any advice i would greatly appreciate it!
  • 8,617 Answers
You need new convergence amp ICs. Please respond to this same post with your model number and I will post the correct ICs for your model plus where you can get replacements with free instalation instructions with pictures.
Posted on Jul 12, 2008
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
Red cross won't line up with white and blue . The red will go side to side but not down???
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My convergence wont adjust on the blue and have no blue in screen
Symptoms:
  • Colors wont align
Feb 20, 2010 | Samsung HC-R4755W 47" HDTV
Tv shows blue halo and double image on screen
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 19, 2010 | Mitsubishi WS-55859 55" Rear Projection...
I am getting a blue halo around text and objects on screen, wheb text is at the bottom the blue halo is curved over the original text.
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Or - your TV may have a convergence problem....
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 20, 2009 | Philips 51PW9363 51" Rear Projection...
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
Blue Halos around people, objects
Sounds like coolant in the CRTs need changing. Blue is always the first color to get contaminated. Hope this helps.
Jan 11, 2008 | Proscan PS50700 50" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
