Question about Epson Stylus Photo R1800 InkJet Printer
Epson R1800 prints do not lay out on paper correctly; off center
When trying to print on standard 8-1/2 x 11 photo paper prints are off center. There is a border around two edges of the paper and none on the other two. Using IPhoto and choosing standard settings, such as 8 x 10 borderless, fine photo paper, etc.  The printer is attached to an IMac (7,1) running a 2.8 GHz Intel Core 2 Duo processor.  I have downloaded drivers from Epson's site previously to no avail. Following the instructions you provided to others I checked the driver using System Preferences and it shows it to be Epson SP R1800 (1). Any help is appreciated
    Genius:
  • 1,447 Answers
Hi-
But goal is to have a borderless printout right? when you go to page setup and choose paper sizes when you go to letter size, does it have a slider for letter- borderless? and when you go to file print and and check the print setting/ print layout is fit to page selected?
keep me posted. Thanks!
Posted on Jul 12, 2008
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
My epson R1800 printer sometimes ejects the paper to soon
I solved this problem by wedging a piece of cardboard in the slot next to the on-off switch. This stop the printer from cycling during the printing due to vibrations.
Feb 17, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus color 3000 printer operate,pause paper out and media type all led lights flashes. What is the problem?
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 21, 2009 | Epson Stylus Photo R1800 InkJet Printer
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
nickerjo,
leaningpalmstudio.com
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
MacBook Pro Epson Print Driver Dilemma
your problem is about profiles. The gutenprint is the only way to print from intel to r1800, but this driver don't use the same ICC profiles. You have to use one of three solutions below:
1 the best, you have a profile calibrating device, you make a profile of your couple ink-paper and you convert your document into this ICC profile.
2 you convert your picture into your software in one of the Epson generic profiles (hey probably still are on your computer) and you print whithout color managment
3 (awful) you anticipate the color distorsion and you tune your picture to be bad on the screen but pretty good on paper.
Feb 03, 2009 | Epson Stylus Photo R1800 InkJet Printer
Paper Selection on my Epsom R1800 & R800 using a MAC
Hmmm, I print from a Mac to an Epson Stylus Photo R1800 and a smaller HP inkjet one. What application are you trying to print from? And are we talking about the R1800?
Oct 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Image and text printed multiple times and are overlapping
Is the R1800 the only printer that you have on ythis mac?
If it is make sure it is directly connected to your mac via a USB or Firewire cable.
Trash epson folder from Mac HD-Library- Printers
Delete Epson printer utility from Mac HD- Application folder( if you have both delete both icon.
Under prnter setup utility delete the r1800 printer
Go to finder click on file the find, type com.apple.print, if it find anything drag it all on the trash, it will not disappear from the window ( the prefs and . cache files)
download the latest driver for your r1800 from epson website
epson12113.dmg - 10.3MB - posted on 12/20/
then reinstall it, after reinstalling try to readd th printer and make sure under print using it will say Epson SPR1800 series. If you see guten print/ that is a third party driver. dont use the gutenprint. then try to print, update me for the outcome
Apr 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
210 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
