Question about Sub-Zero Refrigerators
Sub Zero bottom freezer condensation tray filling with water. Freezer function stops when water is in the tray. empty try and freezer works fine? What is causing the tray to fill up?
  • services Jul 14, 2008
    Response inadiquate. I could have called a specialist in the first place. The freezer is functioning. I am trying to understand what the problem is. Not just generalizations, then call a specialist.
  • Anonymous Mar 17, 2014
    water is filling up in the bottom of my produce trays in my Frigidaire refrig
    Guru:
  • 1,342 Answers
Try cleaning the coils. The unit is self-defrosting too often and not allowing enough time for the water to evaporate.
Under yourrefrigerator/freezer is a set of coils and a cooling fan that you needto clean at least once a year. The coils may look like a grate or likea wide radiator. Unplug the refrigerator/freezer and use a RefrigeratorCondenser Brush (available in the accessories section of our website),and your vacuum cleaner to clean any lint, pet hair, and so on from thecoils.
Appliance Repair Clinic Guide
Posted on Jul 14, 2008
  • 105 Answers
The tray fill may be as aresult of the voltage cut down which fails the proper working of the system this will melts the ice and this will flow as water to the tray.
  • 958 Answers
You can check the condensation tray for dirt or solid objects or ice blocking the drain hole. water should go down to the bottom part of the ref and dries by the heat of the condenser fan. if that drain is clogged with dirt , water would not drop quickly and as the cooling mode goes back, it will freeze the water and clogs the drain and eventually clogged your air circulation and the freezer will not work properly. another would \be the heater that should heat the drain pan. it would run at the same time the defrost heater is melting the ice at the evaporator in order for the water to drain out of the pan. it may be broken or open and no longer heating the drain pan. if it is then you shuld replace the heater.
i hope i was able to solve your problem..
please rate me..tnx drcool
Posted on Jul 12, 2008
    Genius:
  • 1,447 Answers
Hi-
chances are you need to replace the water filter, purchased online at www.subzerowaterfilter.com or via phone at 800-768-0052.
Thanks for using Fixya!
    Genius:
  • 1,847 Answers
How are the temperatures throughout the unit? top to bottom?
you should be 0-10ºF in freezer, 36-40º in fridge, at normal settings, which would be in the middle of each dial or control.
One thing that does cause frozen condensation, or as you described it frozen drops, on the freezer wall is a bad evaporator fan motor, or freezer fan. If this is the case, your icemaker wont make ice cuz its warm at top of unit, and things will be colder at the bottom of the unit, including the water tank for water dispenser, so it wont work either.
as far as the ice in your drain pan area, if it is indeed the drain pan you are referring, should not have ice, though a little may be possible, for that water should ALL go down the drain, if after one day you have some, that will only likely buildup more over time.
It cant be clogged with anything, you've only had it one day. You would have more frost in the first 24 hours, since you are starting from room temperature. therefore you would have more defrost water draining.
    Champion:
  • 217 Answers
There is a certain temperature setting that will not create as much condensation. The colder the temp setting, doesn't necessarily mean it will lessen the condensation build up. Try going for the recommended setting, if it has one on the temperature adjustment. (Or reference the users manual if possible)
  • 2,427 Answers
Your regrigator may need regassing or there is a fan that pushes the cold air, it may need servicing, the problem is condensation, it cloud also be a small leak, call an AC specialest
  • Rishi Roshan Ali Jul 14, 2008
    Trouble Shooting Steps.,,
    Check for leaks and Gas pressure
    1.) connect a Gage and pressure meter to the gas relifim unit on the refgirator, Kepp an eye on the pressure meter and see if it constantly drops, this will alos determin the amount of gas in the unit. The amount of gas necessary is stated on a lable in the back of the Compressor.
    If you determine a leak inject a dye into the gas pipe and look for the blue dots that apperar, Where you see the dots there is a leak.
    If you determine regassing , is necessary regas using the describe gas on your compressor.
    To Check The Fan.
    Look in the bottom of sides for a small vent, There should be a fan located there that pushes the cold air, If its spinning its good if it isnt check to see if its getting power by using a digital multimeter, If the power there but no turn then this will need replacing.
    TO service the Condensation Unit.
    1.) dismantle the condensation Unit, YOu may need to turn iton its side to do this.
    2.) there will be some seals that will need changong as well as the evaporator, Replace with described components..
    You can tell if this needs changing by looking at it while operational and looking for the condensation build up..
    If the Build up is rather fast then its because the freezer isnt cold enough to actually freeze the vapour in the air for the condensation unit to handle the filter the condensed water off..
    If its over a period of time then the condensation unit isnt handling the condensed vapours propperly and will need servicing..
    I trust this is descriptive enough to meet your expectations,, If you require further assistanc then dont hesitate to ask. Please supply the exact make and model you have and i will send you a link to a service manual..
What to do after new water filter installed ice stopped being made?
Need to change water head (the part that the filter fits in).
Aug 29, 2014 | Sub-Zero 650 / O Bottom Freezer...
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
I left the bottom freezer of my 650 ajar and when I returned the unit was producing a loud buzz - presumably a motor or fan. It turns off if I pull the shelf that contains the ice tray forward.
When the door is left open alot of condensation forms in your fridge which freezes and ices up. This build-up will gather around your evaporator fan which sometimes stops it from working or sometimes the fan blades scrape on the ice built up.
Best to manually defrost your freezer. Empty your freezer. Turn fridge off. Put a pot of boiling water and close the door. Leave for some time to defrost the ice. You can repeat this a couple of times to defrost the ice. Otherwise you can use a blow-dryer as well.
When you defrost, and turn your fridge back on. Everything should go back to normal.
Ash
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
My Sub-Zero 561 ice maker works fine however when it dumps ice into the tray and fills back up with water, the water pours out on the right side and into the ice tray. any suggestions
I had the same thing - turns out the wife tried to put a wine bottle in to the ice tray to chill it - in turn it had pushed the water pipe back a little too far and so was causing water to spill out - see if you can pull the pipe forward a little - you will need to remove the ice cube bin - and get in to a funny angle to get to it -but its do-able.
good luck
Aug 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
A whirring sound and leaking water.
See if the drip tray beneath your freezer is full and if so, empty it. That may be the problem. Also, there is a panel between the freezer and the tray. See, if the path provided by the panel, for the flow of defrosted water, is blocked with ice and if so clear it also.
Jul 04, 2010 | Sub-Zero 650 / O Bottom Freezer...
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Sub zero fridge
water filter maybe too dirty
Jul 05, 2008 | Sub-Zero Refrigerators
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Apr 15, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Refrigerators Logo
290 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De GO PATS
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
