Question about Casio Exilim EX-V7 Digital Camera
Focusing feature is no longer working
Hi, my camera is no longer focusing when I try to take a picture. Is this a solvable problem or do I need to purchase a new camer? Thanks.
    Scholar:
  • 93 Answers
Did you try resetting the device by chance?
Posted on Jul 12, 2008
  • Fadil Khan
    Fadil Khan Jul 15, 2008
    A little feedback will be great!!!
Pictures didnt develop
Hi Steph Johnson,
Numerous things could be the issue. 1, dirty lens, clean the front and back element, 2. The camera focus is not working properly not focusing on the correct spot. So, are you manual focusing or auto focusing? If it is auto then there could be an issue with that. If your are manual focusing are you sure your diopter setting is correct for your eyes, if not then it may appear correct in the viewfinder, yet be off focus.
Do you have a way to check the lens on a DSLR? If so you can try that lens on the DSLR seeing if there is an error with the lens or if it is your film camera.
Cordially
Oct 20, 2013 | Canon EOS Rebel XS 35mm SLR Camera
Camera wont focus
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks..!!
Rating the solution is highly appreciated.
Sep 14, 2010 | FUJIFILM FinePix JX250 Digital Camera
Camera Problem
or.......
Thanks for using fixya,
Good luck and have a nice day.
May 09, 2010 | Kodak EasyShare CX7330 Digital Camera
My lens quit auto focusing
It's probably broke then. Clean the contacts to the camera and try again. If it still don't work you can probably be sure it is likely to be a bit faulty. Check the camera has auto focus mode enabled if appropriate.
Jul 06, 2008 | Sigma 28-300mm f/3.5-6.3 Macro for Nikon-D...
Sony Cyber-Shot DSC-W100
if it has changed it's possible you changed the mode to where it takes longer to focus.
for one, this camera has a "constant focus" function that will continuously monitor distance to target and keep the camera in focus, for fastest focusing, switch to this mode. also, are you pre-focusing your images?
Many novices don't know that you are supposed to 'prime' the camera by lightly pressing down the shutter and then when it lights green on the LED light and on the screen, you depress the shutter fully to take the picture. I experience fast picutures this way and I prefer not to even use constant-focus mode. give that a try.
if you don't 'prime' it, the camera basically doesnt know its about to take a picture, so when you hit the button it has to effectively say "OH CRAP picture time!", focus itself, and then snap the pic.
best of luck.
Figit090
Feb 26, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Sad photographer
Sounds like you need to get your camera fixed by Nikon.
However, you say the auto focus stopped working, you didn't switch to a lens that uses a mechanical focus linkage do you? The D40 only supports lenses with AF-S or AF-I type autofocus drives. AF-D and AF-G types without AF-S or AF-I don't autofocus.
Also, check that the A/M switch on the lens is in the correct position.
Manual focusing is quite difficult to do accurately with an AF camera. The screen inside the camera is not optimized for this. If you are sure you are focusing accurately but the pictures you take are still out of focus, the mirror may need adjusting. I can provide further info on this if you require, but if you're within warranty, i'd recommend that route first.
Nov 19, 2007 | Nikon D40x Digital Camera
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cannot focus on a particular subject
If the camera is having a difficult time auto-focusing, you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Focusing distance in macro mode
On a D-580 Zoom camera, the Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Focus
If the camera is having a difficult time auto-focusing you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Casio Exilim EX-V7 Digital Camera Logo
35 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
