Question about Canon Office Equipment & Supplies
Multipass C755 want print. Warnings:
Cannon Multipass C755 (serial # UTW 22347)stopped printing. Warning messages: Cart Return. Cartridge Jammed. Nozzle check.
  • 2 more comments
  • J_JStone Jul 12, 2008
    Cart is stuck, as reported.
    Cart not out in open to remove as suggested by expert.
    Do I just force the cart out in the open? Will this break something?
    Do I just force the cart out into the open to be able to remove the cartridge? will this break something?
    Hey - any body out there - will I break something if I force the cart out in the open?
    Master:
  • 848 Answers
Definitely you will damage if you force to remove cart so better follow the instruction in manual to remove the parts properly....
Posted on Jul 12, 2008
  • 105 Answers
Check whether there is any problem with the catridge and replace it if necessary
  • jithin antony Jul 14, 2008
    try to check the catridge as soon as possible
  • 4,472 Answers
Yes you can definitely break/damage something forcing the carriage. The manual says and I quote.
"Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.:
You can try but you would have to be very delicate.
Good luck,
Lee
  • 3,037 Answers
You should be able to move the cart without breaking anything manually with your hand. Let me know of any other questions that you may have and I would be happy to answer them
  • Canon Master
  • 1,879 Answers
Greetings,
Do not move the print head (where the carts are) manually as it will damage/break it.
That printer service-bound.
Check your warranty status.
We do know that having a printer serviced/fixed costs more than buying a new one. Contact the manufacturer and see what tehy can do for a "loyal customer".
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Master:
  • 497 Answers
If its within the warranty period..i suggest u go by with a professional...if not, open the top cover and remove the cart.gently and clean nossel with clean cloth...if it doesnt clean properly..use a little bit of petrol on the cloth.
Thanks for using Fixya
    Scholar:
  • 135 Answers
Hello sir,,
the procedure is this
Installing / Replacing the BJ Cartridge and ink tanks
The procedure explained here is the same for replacing an old BJ cartridge with a new one, or simply exchanging the BJ cartridge for one of the optional BJ cartridges (BC-34e or BC-30). Click here to skip to installation of ink tanks.
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the handle to open the printer cover.
Multipass C755 want print. Warnings: - c755lifthandle.gif
The cartridge holder automatically moves to the center of the unit.
4. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridgeMultipass C755 want print. Warnings: - c755raiselever.gif"http://i.fixya.net/uploads/images/c755raiselever.gif" alt="c755raiselever.gif" class="h_mi" />
Caution: Spilled ink can stain any surface; protect yourself and your work area.
Note: If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
  • 3 more comments
  • Harrish Mugundhan Jul 12, 2008
    5. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and the protective tape (2).
    Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head.
    Install the BJ cartridge immediately after removing the cap and tape.
    6. Insert the BJ cartridge into the cartridge holder, then lower the blue cartridge lock lever until it locks into position.
    7. Press on the two orange tabs and remove the two orange pieces from the BJ cartridge.
    8. Install the BJ tanks into the BJ cartridge. Be sure to install them in their correct slot. The illustration here shows the correct color array of BJ tanks in a BJ cartridge.
    Start with the far right BJ tank. If you are installing a new BJ tank, remove the packing film by pulling on the orange tape (1). Then grip the bottom of the BJ tank and twist off the orange protective cap in the direction shown (2).
    If you are simply replacing the BJ cartridge and not the BJ tanks, reinsert the partially used BJ tanks into the new BJ cartridge. Be sure to insert them in their correct slot and from right to left.
    For a new BJ tank, carefully remove the packing film taking care not to remove the label from the BJ tank.
    Do not touch the ink port on the BJ tank.
    9. Insert the BJ tank into the far right slot on the BJ cartridge, then press it down from the top until it clicks into position.
    10. For the Color and Photo BJ cartridges, repeat steps 8 and 9 to install the other BJ tanks. Be sure to install them in the correct order and to insert them in the slots from right to left.
    Do not use the BJ cartridge with any of its BJ tanks missing as this can cause the BJ cartridge to clog.
    11. Close the printer cover.
    The LCD displays CART. RETURN while the cartridge holder moves to its home position on the right side of the unit. The MultiPASS then cleans the print head which takes about 20 seconds.
    12. Close the document tray.
    hello sir,,
    NO sir,,It wont damage anything,,,just take care u remove it properly from it seat.
    thank u
    hello,,
    PL donot force the catridge to *** to center one the tray is open. it has to *** automatically
    Genius:
  • 2,035 Answers
  • Anand Kumar
    Anand Kumar Jul 13, 2008
    Power off the printer .Open the covers first and then gently pull the ribbon cable which is at the end of the cable and then try slide the carrier to the center and then power it and check if the carrier comes to center as soon as you open the cover ...Do you hear any slamming noise...
  • Canon Master
  • 19,396 Answers
Check cartridge position on print head rail, try playing with it.
Put printer upside down and inspect printer for small foreign objects.
If this does not fix it, it is likely to be a mechanical fault.
  • 2,427 Answers
Soulds like you need to do a deep in cleaning
click start then printers and faxes
right lick on the printer then choose properties
under the mainenance tab choose deep ink cleaning
do this 2 to 3 times and it should clear up yuour problem
IF that fails
then remove the cartridge and let soak in menthylated spirit for a few minutes
blot it on tisse and that should clear it up
If that fails the remove the INK WELL the think the cartridge plugs into and soak that in menthylated spirit and blot it out
  • 3 more comments
  • Rishi Roshan Ali Jul 12, 2008
    WARNING TRY A REPLACEMENT CARTRIDGE BEFORE ATTEMPTING TO REMOVE THE INK WELL
    Yes you may streach the bands ,,,,
    Do u have the remove the top cover to remove the cartridge
    Open the top cover and remove the cartridge
    Of if your finger can fit in the open space, try to see if the cartridge is pushed out, push it back in
  • 813 Answers
Your cardige nosel has jamed due long time of not use u nee do this put yout cridige nosel for few min nomaly hot water the take one tuse paper & put the nosil on it if ink is spred out then put it in your printer if earror occer then u need to chnge your crdige
  • Canon Master
  • 13,433 Answers
Open the printer check are the carts stuck, remove carts and anything that may be on the way of the carts - power on again, see what happens?
My toner was low, so I replaced it...it printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Thanks,
Pat
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Jammed cartridge error froCanon MultiPASS MP730 All-In-One InkJet
You can open up the device and look inside. You'll prob ably find a jammed peice of paper or a paper clip or some obstacle inside jamming either the rollers or the track for the print head, or both.
Nov 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Print Cartridge errors
there's no connection between developer unit to the dc board
Nov 10, 2007 | Canon Office Equipment & Supplies
Printer Driver for Windows XP SP2
Had the same problem and this is what Canon told me to do and it worked.
Canon has developed a patch that will correct the printing issues that
you have experienced. Please follow these steps to download and
install
file [C755_WinXP_Updater.exe].
1. Using your Internet browser visit http://www.canontechsupport.com.
2. Select the following from the list below [Please choose your
product from the menus below] drop-down boxes:
2-1. Select [Multifunction] from the first drop-down box.
2-2. Select [Inkjet] as the Product Type from the second
drop-down
box.
2-3. Select [MultiPASS C755] from the third drop-down box and
click 'GO'
3. On the Support page for your unit, click the 'Setup Instruction'
link. A new window will appear.
4. Click on 'Drivers / Software' tab.
5. Click [Windows XP Update for Windows 2000].
6. Read the disclaimer and click on I Agree - Begin Download.
7. Read the provided instructions, and then click on
8. In the File Download box, click [Save].
9. When the Save As box comes up, choose Desktop and click Save.
10. Once the download is complete, close all windows.
11. On the Windows desktop, double-click on [C755_WinXP_Updater.exe].
12. After the file has been extracted, click OK to begin the update.
13. Once the update is completed, click YES to restart Windows.
Installing this update will fix the printing issues.
Please let us know if we can be of any further assistance with your
MultiPASS C755.
Thank you for choosing Canon.
Sincerely,
Thomas
Technical Support Representative
Special Note: Certain issues are very difficult to resolve via email.
If your question remains unanswered after you have received this email,
you may call our special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m. (excluding holidays).
If you prefer to continue to communicate via email, reply to this
message and we will respond as quickly as possible.
*Telephone support for products no longer covered under the
manufacturer's warranty may require a $9.99 fee for support.
Oct 28, 2007 | Canon MultiPASS C755 All-In-One InkJet...
Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
51 people viewed this question
old marine
old marine
