I have a Belling DB1000DF Range cooker, which stopped heating up last night. Oven was on, light inside on, red light outside on and fan running. Oven had warmed up to about 80 deg, but was not then getting any hotter. Turning the temp knob triggerred the red light on/off as normal. I checked the electric monitor we have and there was no change in amps when turning the temp up/down. I move the function knob from oven/fan to just oven and the amps went up and oven started warming up. The smaller oven is working ok and all other main oven functions work ok (grill, etc) it's just when I select oven and fan that the fan comes on but the oven doesn't heat up. Any help would be appreciated.
Oven is 3 years old and retailer says it should work fault-free for 6 years. We have to call out Belling (at our expense) to repair (probably fan heating element) and then send receipt to retailer to claim a refund of the costs.
I'm happy!Oven is 3 years old and retailer says it should work fault-free for 6 years. We have to call out Belling (at our expense) to repair (probably fan heating element) and then send receipt to retailer to claim a refund of the costs.
I'm happy!
You can't post conmments that contain an email address.
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
For all Free appliance repair videos visit our VIDEO
TUTORIALS1, If the Belling fan motorin the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter. To gain access to the BELLINGelement you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the elementyou will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine.
2, If your BELLING fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your BELLING oven thermostat 4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie:
no heat and no fan then the chances are that someone has put the oven timerinto AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
from the rear of the machine. 2, If your BELLING fan
If the fan is working o/k, then it is sure to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
i assume you mean the casing fan and not the fan inside the oven. this is controlled by a fan stat which is inside the casing. cheap part and easy to fit. iv forgotten the exact location but remember it located at the top
TUTORIALS 1, If the Belling fan motorin the back of the oven is going round and
I'm happy!
