Question about Graphics BV200 BizView 128MB (128 MB) PCI Graphic Card
Looking to buy a new graphics card
I was recently given an e-machines t3642. This machince has 2.- gigs of ram, 400 gb of memory, an amd athlon 64 processor 4000+, has windows vista and a nvidia geforce 6100 nforce 405 graphics card. I am looking to upgrade the graphics card for my games but am not sure what card would be suitable for my computer without having to add too many more things to the computer. Any advice would be most appreciated! Thankyou!
  • 2,794 Answers
You have a PCI Express slot to put a graphics card in. You can get a bigger graphics card to install in the machine but the power supply you are using in your comptuer is only 300 watts. If the specs of the memory card tell you to upgrade the power supply if its blow x amount watts you will have to do that in order to not run into problems. The good thing about e-machines is that you can upgrade the power supply at the same time. Usually they don't cost a lot of money.
You might have to get one thats around 425 to 475 watts depending on what the instructions tell you. If the new video card you are using is running a fan for cooling, chance are it will need an upgrade.
Posted on Jul 12, 2008
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
I have an ET1161-05- can it be upgraded to hold more memory and run faster?
Hi.
Yes, your computer came with 2 gig's of ram in the form of 2 1gig modules of ddr2 ram.
There are 4 slots for memory all together, and each slot can hold 2 gig memory chips in each one, for a total of 8 gig's of ram!
That would cause a serious performance improvement for you.
It also came with a 160 gb hard drive, so if you want to, you can get as larger drive as well.
As far as processors, a dual core, AMD Athlon 64 X2 5600+ Brisbane 2.9GHz 2 x 512KB L2 Cache Socket AM2 65W processor will fit in with absolutely no bios updates required, so all you would have to do is take the old processor out, put the new one in, and turn the computer on.
It will recognize the new processor automatically, and will work right away!
This will have a significant performance boost, possibly doubling the total speed of your computer.
I hope this helps you out, and have a good day !
May 26, 2011 | E-Machines eMachines Desktop PC
Well i have a compaq presario sr1603wm and basically i was going to buy a new computer but thats like 600 bucks so i was wondering... what kinds of graphics cards/ram/processors/power supplies can i use to...
you can use these processors:
AMD Athlon 64 (3000+ - 4000+)
AMD Athlon 64 FX (51 - 60)
AMD Athlon 64 X2 (3600+ - 4800+)
Some AMD Opteron 1xx series
Some Sempron 3x00+ (Step E3,
any standard wopeer supply will do, and you will need a more powerfyul power supply for a mre powerful graphics card.
you can get any pci-e card. an nvidia 9800gt used to be the 2nd best graphics, but its now the minimum card for gaming. I wqould reccomend a 9800, or at least an nvidia gtx260. the higher the numper, per series, and the 4xx and 5xx series are btter than the 2xx. be sure to check the graphics card for reccomended power supply rating.
for the ram, you need pc3200 DDR ram(DDR-400) or higher DDR ram, not compatible with ddr2 or ddr3.
Mar 18, 2011 | HP Compaq Presario SR1603WM (ED861AA) PC...
My wife's computer is an Acer Aspire 5100 with a 4000 AMD Athlone 64 processor. It came with only 1 GB of memory and is runniing Vista Home Basic. It is terribly slow and I would like to increase the...
yes one will be for single channel ram the other for daul channel ram.if you have the acer owners manual it will tell witch ones are single and witch one is daul.
Sep 21, 2010 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Chip up grade options!
That
is a socket 754 motherboard. It will support AMD Athlon processors up to Athlon64 3400+. It is a bit long in the tooth by today's standards, and only uses DDR memory, not DDR2. You may get more of a bang for your buck by buying a "barebones" system, which can consist of a motherboard with processor and memory, depending on how much you want in the barebones package.
Typically you use the case, power supply you already have with the new motherboard and processor and ram (memory).
At any rate, if you only want to upgrade your processor, keep in mind that your board only supports up to the Athlon64 3400+. It will support up to DDR 400 ram. You would probably benefit more by buying 2 sticks of 400 DDR ram at 2 gigs each, if you don't have much ram now. If your processor is close to the 3400+, then another processor in that board isn't going to change things much.
Good luck, and write back if you'd like more help.
Sirwriter
Socket754 Supports AMD Athlon64 upto 3400+;
Nov 02, 2009 | Computers & Internet
Upgrade Gateway AMD Athlon 64 Processor 3500+
friend
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
easy...
thanks
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Playing CRISIS..
heres more info on the game
http://en.wikipedia.org/wiki/Crysis
Operating System - Windows XP or Windows Vista
CPU Minimum - 2.8 GHz or faster for XP, 3.2 GHz or faster for Vista
cpu Recommended - Intel Core 2 Duo @ 2.2 GHz, or AMD Athlon 64 X2 4400+
Memory - 1 GB RAM for XP, 1.5 GB RAM for Vista
Recommended - 2 GB RAM
Hard Drive Space - 12 GB of free space
Minimum Graphics Hardware - 256 MB video memory, NVIDIA GeForce 6800 GT/ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater
Recommended - NVIDIA GeForce 8800 GTS 640MB or ATI 2900XT 512MB
Sound Hardware DirectX 9.0c compliant card
Jun 16, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Graphics BV200 BizView  128MB (128 MB) PCI Graphic Card Logo
59 people viewed this question
Top Graphics Computers & Internet Experts
David
David
Vernon Taylor
dhnguyen
Are you a Graphics Computer and Internet Expert? Answer questions, earn points and help others
