Portable a/c leaking
Help--Unit leaking from bottom near drain plug. Have connected drain hose but still leaks.
  • burzerko
    burzerko May 11, 2010
    Have you checked to see if there is a hole causing a leak or possibly the drain nipple may have broke around the pan weld.
    Champion:
  • 254 Answers
Check to see if the fitting is cracked at the enterance to the condensate drain pan. Also check to see if it is level the correct pitch to drain is 1/4" per foot.
Hope this helps Ya
please rate me
Posted on Jul 20, 2008
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
May 27, 2015 | Haier HPRD12XC5 Portable Room Air...
Why is our dishwasher leaking water
There are 4 places it could be leaking. 1) at the connection where the water line connects to the dishwasher. If the dishwasher has been in operation for a long time then this is not likely to be the problem. If this were the problem you would notice water even when the dishwasher was not running. 2) at the drain hose connection. You would notice the water during and shortly after a drain cycle. The drain outlet is usually a hard plastic over which the rubber drain tube is clamped. Either the plastic could crack or the hose could dry out and crack. 3) The seal around the pump could be leaking. 4) The door seal could be leaking, though this in not usually the problem. You can probably determine the problem by removing the bottom panel so that you can see underneath the unit, and then run a cycle. There are usually 2 screws between the door bottom and the lower panel (near the sides of the machine) and 2 more screws at the
bottom of the lower panel (the recessed part of the panel) near the sides. Don't stick your hand under there because you will have power to the unit and a wet floor. That is a bad combination which could be lethal. Just shine a flashlight under and see where the water is leaking from as it runs. Remove power at the circuit breaker before trying to do any service on the unit.
Aug 22, 2014 | KitchenAid Dishwashers
I just purchased a used wintair room portable a/c unit, works good its 8000btu, it cools great, but i dont know how to work the buttons, and it has started leaking on my daughters carpet, do i need to...
There should be a plug on the rear of the unit near the bottom of the back. If the plug is missing/removed, it should have a barbed or threaded end for a drain hose to be installed. Place the drain hose (a typical garden hose will suffice) over the end of the barbed/threaded section and secure with a an automotive hose clamp. Some units did come with a "male" hose end in which the "female" end (what you would screw onto a outdoor faucet) garden hose can be directly threaded onto the drain connection. In either case, this drain needs to be leak proof to prevent additional water (condensate) from leaking onto the floor. The drain is ideal for situations where there is high humidity in which the A/C condenses the water vapor out of the air during A/C operation.
Feb 06, 2018 | Danby Portable Air Conditioner
Leaks water out of bottom
hi friend,
Evidently you have reason to believe your washer is leaking. Probably there is water on the floor near the machine. Fine, then the first thing is some detective work. with an absorbent hand towel begin to inspect the areas where water enter or leave the washer. Those places are: 1. the hot and cold water inlet hoses located in the back and top of the machine and 2. the washer drain line, located in the back and bottom of the machine.
  • Step 2 One at a time, dry both ends of the hot and cold water hoses. watch for water to bead up. Water may be leaking from more than one place so don't stop with the first leak you find. Inspect all four possible connections and the hose itself. If there is a leak at a hose connection it's an easy fix. shut off the water supply of the leaking hose, unscrew the hose where it leaks and wrap Teflon tape clockwise around the threaded or male part of the connection. inspect the flat rubber washer in the female part of the connection. replace if it seems very worn. re-tighten the connection, dry and turn the water back on. check for the leak to return. If the leak in somewhere on the hose itself you will need to buy a new hose. Hot and cold water hoses are marked.
  • Step 3washingmachine3_thumb.jpg Next we need to check the hose where water drains from the washer. It comes from the washer near the floor level and usually inserts a male into the female of the washer hole. It then moves to the drain leaving the house. Again, dry the entire hose. Then you will have to run the washer. Use flashlight and inspection mirror to help you look for a leak during the draining process. If it leaks at the connection to the washer try reinserting and tightening the retaining screws. There usually are no threads to wrap. If that doesn't fix the leak or if you find a leak in the hose itself you will need to replace it.
  • Step 4 If you still have a leak under the washer it is probably in the drain hose between the drain pump and the outside hose or the short hose between the tub and the drain pump. This may be getting out of your level of competence. But if you want to be a Renaissance Man, give it a try.
    Unplug the machine. Now you need access to the bottom of the machine. depending on your brand you may be able to 1)remove the front by inserting a painters scraper and prying the spring snaps up, 2)remove the back by taking out screws and the rear plate or 3)you may have to go in through the bottom. With help tip it over on it's side. of course the machine will need to be empty of clothes and water as it's heavy enough already.
  • Step 5 However you access the inside bottom of the machine you will see a rubber hose coming down from the tub to a small electric drain pump then a plastic line will leave the pump and go to the back of the machine where it will meet up with the drain line you inspected in step 2. With your inspection mirror and flashlight look for water to indicate a leak. These lines are often held on by metal springs and can be moved or adjusted with open jaw pliers. If you find one of these hoses damaged take it off and bring it with you to your appliance store for a replacement.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • take digital photos before you remove any part. if you get confused you can use it as reference
    • don't work on the inside of the washer with it plugged in.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 24, 2009 | Maytag Washing Machines
    Leaking unit
    check to ensure that the drain hose is not touching the side if the water storage bin. if still no luck then watch unit when running to assess the leak point............maybe a hairline crack in water container
    Oct 30, 2009 | Heating & Cooling
    Dishwasher leaks from bottom left corner
    If its just that corner check that it is level (if not leak could be somewhere else)
    Then check your hoses and valves for holes or leaks (try putting some food dye water when running to see easier
    Most likely a loose hose connector or hole in the rubber hose
    This hould help you
    Dishwasher Basics The main parts of a dishwasher are: Control mechanism
    The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
    This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
    An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
    • Reversible
      These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
      -->Reversible pump
    • Direct-drive
      The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
      -->Direct-drive pump
    Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
    Jun 07, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
    How can I fix my Kenmore portable washer 100.49722990?
    Most common cause for water leak
    is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
    if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
    Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
    We purchased a Whirlpool portable air conditioner in 2005 from Best Buy. Near the end of last summer the air conditioner started leaking water. We started using it again this season and it is still...
    Check to see if the drain is blocked by particles/debris of any type. Also make sure that the unit is level--as level as possible. I have my Whirlpool Portable AC in 4 inch bed risers so I can drain it really easily. I slip under a small low rise pan and drain it every two days or so when it is running. Mine leaked when I tried to incline it backwards to make it drain faster. As soon as I leveled the unit the leak stopped and water again came out the hose. These units must be kept level to prevent leaks so now I always do that.
    Jun 09, 2008 | Whirlpool Heating & Cooling
    Heating & Cooling Logo
    126 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
