Peavey microbass amp won't switch on after sitting unused in the garage for about a year. Changing the fuse in the plug had no effect...
  • 682 Answers
Please leave it for a couple of days in sun exposure(not connected to power)-and then bring a box or carton bigger than the size of amp and put it in the box with good quantity of rice and leave it for a couple of days(rice absorb the humidity).
Posted on Jul 12, 2008
Peavey tnt 115 blowing fuses
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Peavey xr600f
250V 8A SL(Slow-Blow)
Sep 29, 2013 | Music
How do i use the effects loop on peavey xr 600b?
plug the effects out into the input of your reverb/echo unit, plug the out put of the processor into an unused channel in the mixer, do NOT turn up the effects in that channel, to hear the effects in the main use the main level, to hear effects in the monitor use the monitor level. you must turn up the the effect send in the channel you want to hear the effects on and also the effects master.
Jan 23, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
I use my Peavey XR 8600 with an acoustic duo that I'm in. At my last show, an audience member grabbed and dropped a vocal microphone that sent a sharp sound through the Peavey and shut it down. When I...
Chances are one of the power amps has shorted. Replacing the fuse probably fried additional components. Unless you are electronically adept this is NOT a DIY repair.
Expect that this is going to be an expensive repair as often quite a few transistors and other components fry when one goes in these power amps.
Mar 09, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I've lost both channels. if you plug into the amp and turn it way up you can hear a very low output on both channels
Hard to say what device you have. Peavey makes a lot of things.
If this happened to be a peavey amp that has effects send/receive, a bad "send" jack could cause the problem due to the integral switch that sends the signal to the power amp.
Nov 01, 2009 | Peavey Music
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
I have a Peavey Microbass 20 watts and I need the schematics in order to repair it myself. I'd apreciate any advice to find this papers.
These are available from Peavey, but not for free. Expect a cost in the $20 range. Contact Peavey directly and ask for either service or parts.
Dan
Jul 20, 2009 | Audio Players & Recorders
Peavey microbass guitar amp
The hum is usually electrical mains hum at 50hz, i wouldn't recommend messing about with the insides of amps!
Jay.D BsC Music Technology
SEO Experts - Optimise your web business and increase traffic
Dec 14, 2007 | Audio Players & Recorders
104 people viewed this question
 Grubhead
Grubhead
