You can Unlock the LG KS360 from only GSM network lock mobile,Not able to Unlock it from CDMA Network,.Because Boost is CDMA Network...So not able to Unlock,If it locked GSM Network means You can get the Unlock code at http://www.onlinegsmunlock.com/lg-ks360/rs7wp9/ reliable cost and Unlock LG KS360.
SOURCE: need unlock code for lg ks360 mobile phone
Hi Friend,
Kindly follow the instructions in the below mentioned link and you can find by your own the unlock code
http://www.pb4kn.co.uk/ks360_unlocking.htm
If this is helpful and solved your problem kindly rate this
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: I would like to unlock LG KS360 mobile from BOOST
only the mobile phone service center can help you with the unlock codes.because each mobile phone has its own unique unlock code.and there are several thousand mobile phone device.as you give the imei number the service center of the mobile will porovide you with that code.as they do not mention this codes online and provide it for free.its necessary to get it from the service center,or from the websites who sell this codes which they get due to their contact with the service center.thats the only way.
SOURCE: Boost Mobile SIMs and Motorola V3 Razr compatible or not??
will not work with boost mobile, (even if it is unlocked) you might be able to use it with boost mobile cdma, which uses sprint service. they no longer advertise this service, but still accept new users. give boost a call and ask them for the boost mobile cdma number
SOURCE: how can i unlock a boost i856 phone to work with a
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security Code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (Security Code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This may be a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Testimonial: "great stuff!"
