Gigabyte GA-N680SLI-DQ6 Motherboard Logo
Anonymous Posted on Jul 12, 2008
Just askin! where i should get Gigabyte N6980SLI DQ6?
Anonymous
Level 1:
Scholar:
  • Contributor 58 Answers
  • Posted on Jul 12, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
58
Questions
0
Helped
8551
Points
95
Hi.
I think you should do a google Search.
Hope this help you.
Good luck.
Markfun_load_nt_driver
Hello you can find drivers, and the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=2637#dl
Maybe the harddrive is damaged, or you have a virus.
Try to install windows again.
Good luck
Problem Booting Motherboard After Overclock
hi unplug tour cpu chassis just remove the battery found on motherboard for 5 minutes then put it back inside
1helpful
I overclocked my Gigabyte GA-X48T-DQ6 motherboard and now it won't boot
If you mean that nothing appears onscreen when you press the power button but you can hear the fans working then try this.
The quickest way to restore default bios settings is to remove the battery on the motherboard.
Important ..... Disconnect the power leads FIRST
Gain access to the motherboard and search for a small coin shaped battery. Note which way it fits into the holder, then remove it and leave the PC for 5 minutes. If you have a manual you can also check for jumper settings to discharge the bios battery.
Refit the battery (the correct way) and plug in the power lead. Cross your fingers and power up.
1helpful
Can not copy a part of XP OS file
Hi there.
Go here to Gigabyte support and download the BIOS update you need>>>>>
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_List.aspx?Keyword=GA-P35-DQ6
Good luck and thanks for using FixYa!!
System temperature too hot
Its measured in Celsius. Meaning alot higher in Fahrenheit. That would be the Processor.
You are looking for something that will be Square or on a Card that is in the motherboard.
Gigabyte motherboard driver
The problem is not with *********** Board. Check the front panel audio connectors inside your CPU are connected to *********** Board properly.
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
