Question about GE JVM1750SMSS Microwave Oven
Help some bottoms form de control panel aren't working is there a way for me to take a look from the inside
  • abigailbrdel Jul 12, 2008
    need to know ho to fix it
  • GE Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it still fails, I would say you need a new keypad.
If so, I would suggest you contact Delonghi at the number in your owner's manual or visit here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
I have DME321XE16 De Dietrich microwave. I have a problem as for the past week I have been able to smell a burning plastic smell coming from the control panel when microwaving something. I have checked as...
i would recommend not to operate it in this situation & should be opened and investigate the cause of the smell, most likely it'll be a very hot component on the board or a freaky contacts.
Oct 29, 2017 | Microwave Ovens
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
Is there an internal light in the NNT664SF
Yes, there is a light on the right hand side of the microwave (looking at the control panel). It is located directly behind the control panel and may be seen with a flashlight looking inside the door through the perforated metal housing. Four special hex-with-stem screws must be removed from the cover to access it, along with one standard Phillips head screw on the side. Once the screws are removed you must slide the cover toward the back about 1/2" before it will be able to tilt up and be removed.
For safety reasons make sure to unplug the unit and allow it to discharge before removing the cover. Also make sure to not touch anything you aren't intending to work on - it could be carrying power from the capacitor, which is like a battery, and might not be discharged while you are poking around inside.
I am currently seeking out a replacement lamp for mine. I could not find one at any of the local hardware stores as this has a proprietary base and the bulb is not removable from the base. I will be looking on ebay and elsewhere.
Oct 02, 2010 | Panasonic NN-T664SF Microwave Oven
Mic daigram
We have the service manual for it here.
You'll also need to refer to the tech sheet hidden inside the unit, either behind the control panel or on the bottom left side inside near the bottom.
You should be able to get parts affordably by looking up part numbers here.
Let me know if I can help further.
Aug 20, 2010 | Amana HDC21 Microwave Oven
Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find helpful exploded view diagrams and order parts here.
Nov 22, 2009 | Microwave Ovens
I have a Maytag mmv5207aas microwave. It does not work at all. There is power to the outlet but the unit is completely dead. I understand there are internal fuses I can check. How do I get to the fuses? Do...
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It may be the fuse, or the magnetron thermostat (thermal cutout ./ TCO) or the oven cavity thermostat.
The first two can be accessed via the control panel opening, but if you need to check or replace the oven cavity thermostat, you will need to remove the oven form the wall.
Removing it from the wall is ideally a 2-person job and you should have your installation instructions handy. If not, you should be able to find it here.
Be sure to unplug the oven before you begin.
Dec 13, 2008 | Maytag MMV5207AAS Microwave Oven
De Dietrich DME 112 XU2 Turntable not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Dec 13, 2008 | De Dietrich DME112X Microwave Oven
GE model JVM1340WW002 My microwave was working and stopped in the middle of cooking. Timer works, but fan does not blow and turntable does not turn.
I would say this is is a problem with the bottom door switch.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There also should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 23, 2008 | Microwave Ovens
Model# DME315XE14 (17 months old). Control panel is not displaying properly so although the microwave is working, I am unable to set the clock or display the length of time or the wattage. Hope you can...
The control panel can be repaired or replaced, depending on the quality level of the technician or engineer doing the work.
You can contact DeDietrich here to find an authorized repair center in the UK.
Aug 04, 2008 | De Dietrich Microwave Ovens
How to open the control panel to troubleshoot no power failure condition?
We have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
Jul 24, 2008 | Whirlpool GH7155XHS Microwave Oven
GE JVM1750SMSS Microwave Oven Logo
97 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
