Question about NEC MultiSync 1525X 15" LCD Monitor
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
The display on the ncd lcd 1760v stays for 2 seconds and blank screen after that. Tried changing the resolution setting on my computer but it didn't help. Even without the VGA cable it behaves the same way. The monitor displays there was no input signal for 2 seconds and blank screen after that. I appreciate any help in fixing the issue
The inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Posted on Dec 03, 2008
Issue might be with the power supply unit - PSU, or the processor/motherboard
Posted on Jul 18, 2008
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
An 'etch-a-sketch' - type image that at quick glance, looks like an elephant, appears in the upper right section of the screen. It isn't captured with print screen. Swapped out monitors to different CPUs....
I did see a similar issue with a Gateway display, the source of the image was the screen is damaged by the cover inside the screen. Basically, the inside frame was scratching the back of the screen making the image to appear until it damages the screen enough to turn off pixels.
Another possible cause are: "burned pixels", some kind of damage (liquids inside the display), the display was hit, or something like that.
The only solution is to replace the display or use it until is breaks (but it will be quite annoying).
Mar 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I have a NEC LCD 1760V and the resolution notifier keeps popping up. How do I eliminate this problem. It keeps telling me to exit.
insert the AGP card in the AGP slot in install the drivers the problem will be definatly solved the card should be of 8X grade
Mar 04, 2010 | NEC-Mitsubishi Nec Display Solutions...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Apologies if you got this?? i dont know how this works???
Here is the link for your manual that will help you with your resolutions and screen position. Really easy. Nice monitor : http://www.necdisplay.com/cms/documents/UserManuals/LCD1760V_manual3.pdf
Mar 17, 2008 | NEC MultiSync 1760NX 17" LCD Monitor
Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
Jan 02, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
Computers & Internet Logo
383 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
