Question about Refrigerators
HOW T CHANGE THE TEMPERATURE - Refrigerators
  • GARY SWANSON Jan 20, 2009
    COOLER TEMP IS SET AT 54 WHICH IS REC FOR REDS. IN THE MANUAL IT REC 46-54 FOR WHITES BUT CAN NOT SET IT BELOW 54. HOW DO I SET IT TO 46?
    NEED TO SET MY FR966 COOLER TO 46-54 DEGREES LIKE REC IN MANUAL FOR WHITES. HOW DO I ?
Freezer is cooling but fefridgerator is 60 degrees
Posted on Jul 12, 2008
I change the temperature sensor but the needle does not move how can I change the needle? This is a 95 ford Econoline 350
you have probably been misinformed. The needle on the temperature gauge is controlled by the temperature SENDER unit ( not the temperature SENSOR unit) The sender unit is a single wire unit that is a resistance unit affected by heat of the coolant, The hotter the coolant the less resistance the higher the reading
The temperature sensor unit is a 2 wire unit that tells the ECM when to switch on the fan, when to go into limp mode if overheating and when to adjust the air/fuel mixture as the coolant warms up
Oct 20, 2014 | Ford Cars & Trucks
I can't see how to change for C to F temperature. Something happened when I put in new batteries.
Can't see much in the photo, but in general, push the "SET" button repeatedly to scroll though all the settings. Temperature UP and DOWN arrows change the settings when the display is flashing. Press "RUN" to lock it all in. Hope this helps.
Dec 13, 2013 | SkyScan Atomic Clock with Outdoor...
Cant change the temperature
What is the complete model number of the unit?
Dec 03, 2012 | Refrigerators
How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Feb 08, 2009 | Maytag MGS5770 Gas Kitchen Range
TURBOCHEF C3 AND TORNADO
what setting. the code to get into diagnostic area is 9428.
Nov 22, 2008 | TurboChef TORNADO Electric Oven
Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
  • Press either ARROW and hold for about 1 second to enter the Manual Override Mode. When display flashes, you can release the key.
  • Press the ARROW to change to your desired Temperature
  • Press HOLD/RET to return to normal mode, or wait 15 sections for it to return automatically.
  • The current program number will flash to signify the Temporary Overide.
  • At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature.
Hope this is what you need. God Bless.
Jun 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
