Question about Audiovox 8610 Cellular Phone
Contact information The top of my flip phone (with the screen) seperated from the bottom after an amusement park accident. Otherwise phone still works. I'd like to retrieve my contact info (names & numbers). Mfg says the only way is to fix it which will be very expensive. Is this true ?
  • ChristianU Jul 12, 2008
    I took it to a Sprint store & a tech pluged it into a "black box". They said they couldn't get the info because they were not allowed to work on Virgin Mobile phones. Is there somewhere I can take it ?
  • 550 Answers
When i drove over my lg phone and also smashed the screen, it was still accessible through the data cable to the computer and I was able to download everything and upload to the replacement. If you have the software try it, if not the software may be(will be) far less expensive than a screen eplacement
Posted on Jul 12, 2008
I have one telephone number in my phone that is on mute so that when she texts or calls me it doesn't alert me
The contact is probably Blocked. It happens by accident sometimes.
On iPhone, go to the Contacts App, Find the affected contact and select it. Scroll to the bottom and select 'Unblock'.
On android it can vary. In general... Go to Contacts app...Select the Contact that is not ringing. Now, select the 3 dots in top right of the screen. There should be an option to 'Unblock'.
Also added guides with pictures I found online for you. Hope this helps.
How to Unblock Phone Numbers on Android Block calls and block or filter messages on your iPhone iPad or iPod touch
Oct 25, 2016 | Cell Phones
HOW TO SEPARATED FLIP DOOR TO HOUSING??
Hello!! In order to separated the flip door use your fingernail to
lift the top of the lens and pull it away from the phone and to put it into place just Insert the tab at the bottom of the new lens into the bottom
of the phone flip, then use your thumbs to press along the sides of the
lens as you press it into place.
You can check for this information from the manual:
http://www.manual-owner.com/wp-content/uploads/2013/02/3721106-Motorola-V180-mobile-phone-manual.pdf
Best Regards.
Karen
Customer Support
Aug 14, 2014 | Motorola Mobility V180 Cellular Phone
Why does my phone screen stay white?
it will be alright after 30 days. Be calm and quiet.
Aug 11, 2012 | Samsung C3050 Cell Phone
Monitor screen flipped sideways how do I return to top to bottom
Hold Ctrl+Alt,then use the arrow key to select the top of the screen(in your case Ctrl+alt and up).My father in law who is actually trained for some PC repair called me with this stumper,I played with mine and stumbled on the solution by accident.
Mar 13, 2012 | Computers & Internet
How do I add phone number(s) to my contacts? on my Lg Ally
How to Add Contacts to the LG Ally
1.Touch the "Contacts" icon on the screen of your LG Ally. The "Contacts" icon is at the bottom of the screen. The icon is a gray and white rectangle with a thin green bar across the top.
2.Press the "Menu" button on the bottom of the LG Ally and touch "New Contact" on the screen. The "Menu" button is the third button from the left in the row of buttons.
3.Slide the phone open to access the keyboard and enter the name of your contact.
4.Touch any of the information categories and enter the information using the keypad. Information categories include phone number and email address.
5.Tap the "+" icon to add more information categories, such as additional phone numbers or email addresses. Tap the button next to the new information category to access a menu of category names, and then enter the information using the keypad.
6.Press the "Picture Frame" icon on the screen, which is a white and gray rectangle with a "+" on it, and then touch one of the pictures in your album to assign that picture to the contact.
7.Touch "Done" on the LG Ally screen to save the contact to memory.
hope this helps
Apr 14, 2011 | LG Cell Phones
LG VX5300 Flip Phone broke in half.
Your phone can work again, all you need to do is to get the flexi cable and fix it back in place.
It is not expensive.
It is about $15.
To fix this, these are the processes to follow;
  1. Get the appropriate screwdriver,
  2. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  3. Next remove the 2 rubber stoppers and unscrew the aerial.
  4. Remove the 6 screws,
  5. Next remove the 2 rubber stoppers & screws above the main screen,
  6. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  7. Unclip the ribbon,
  8. After removing the ribbon cable, carefully lift the metal part that is beneath the phone. Another ribbon will be attached which should be carefully removed.
  9. Take the circuit board & keypad out and you'll be left with what's below it.
  10. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  11. To open the top half of the phone and get to the screen, run your fingernail between where the two parts of the housing meets,
  12. Try to open up the top part by splitting it open with a credit card,
  13. replace the ribbon and,
  14. Reverse the procedure for reassembly and it's finished.
Take care
Jun 21, 2010 | LG VX5300 Cellular Phone
How do i replace flex cable on a razor phone can u show video
Ok..#1.take the battery out..
then youll have to remove the 2 screws that hold the modem part of the phone in.gently pryup on the modem ,on the side with out the usb charger port..slip a thin flat tipp screw driver in there and slide it towards the bottom of the phone. there are littler plastic clips carefull not to break them.then youll see where the bottom of the flex cable plugs in.unplug it.then flip the phone over,in the 4 cornors of the screen side of the flip there are tiny little rubber plugs. pop them out and undo the screws in there.near the top of the screen there is a little slot on the right side of the screen ..gently pop the cover off the screen..unplug the flex cable from the screen.and carefully remove the screen.be careful not to damage the buttons on the sides of the screen.then close the flip and turn the phone over..looking into the battery part of the phone,on the top right hand side of the hindge there is another little screw,remove that.then again turn the phone over and stick a flat tip screw driver into the open hole and pop the chrome roller out.then very carefully youll be able to seperate the 2 halfs. look on the back side of the keyboard youll see little metal tabs folded over that holds the key board in place..the keyboard and the flex cable are one piece, just revers the procedure to replace.." BE VERY CAREFUL RUNNING THE FLEX CABLE THREW THE HINGE AS IT CAN DAMAGE VERY EASLY." IF YOU NEED MORE ASSISNT CONTACT WWW.PHOENIXTEC.CA they are very helpful
May 11, 2010 | Motorola Mobility RAZR V3
When a call is parked, we only have a minute to divert the call otherwise it then rings all the phones is there a way of delaying the set time period?
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the next key 6 times (bottom right arrow) .
The display should saySystem Prgrming.
Press the show key (top right arrow)
The display should say Hunt groups
Press the next key 2 times (bottom right arrow) .
The display should say Featr Settings.
The display should say backgrnd Music
Press the next key 4 times (bottom right arrow) .
The display should say Park Timeout:60
Press the Chng soft key till you change the park timer to the desired time length.
Press the release key when finished
Oct 01, 2009 | NorStar T7316E Corded Phone
Screen shows black at top and bottom from flip video hd
I think you can use doremisoft flip converter that can crop your black bars and other addition editing functions, such as cut clips, join videos, add special effect and so on.
YOU can free download at:
http://www.flip-converter.com/article-flip-mac/flip-video-to-avi-converter-mac/
have a try.
May 25, 2009 | Pure Digital Flip Video Ultra Camcorder
Cracked i880 screen
It is possible but can be difficult. there are seven T6 screws two of the are hidden under cover plugsa the bottom right and left corners of the phone on the rear. there is also one near the top left hand corner near the antenna.Once open you will see that the phone has a ribbbon cable that connects the flip to the main board. Carefuly remove the cable and replace the flip..then make sure to seat the new flip correctly and replace the backhousing and screws..good luck
Jan 01, 2008 | Motorola Mobility i880 Cellular Phone
Audiovox 8610 Cellular Phone Logo
57 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Computer Repairing
Computer Repairing
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
