Question about Motorola Mobility E398 Cellular Phone
E398 water damage
I have a motorola e398 water damage... help...
the unit is grounded i think the problem is in charging ic coz when i remove it it is not grounded but the unit will not turn-on. can you please help me any jumper point in the circuit. tnx...
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
Motorola e398 inser sim please setting
saya mau tanya neh gan....gmn ya solusi dari motorola yang insert sim.....padahal ic PA sudah saya cetak ulang
Feb 05, 2011 | Motorola Mobility E398 Cellular Phone
My nokia x3 fell on water. i dried it overnight by putting on battery. on putting the battery back, main screen coming but upper keypad(call,shift keys,quit buttons) not working. i m not able to switch it...
Electronics and water dont mix, what you should have done is as soon as you retrieve the phone from the water, is remove the battery, then bringing it for repair, as opposed to what you have said that you let it dry and then re-installed the battery.
Cellphones, specially Nokia, well all of them, have IC's or circuit compnoents,as all electronics have, the only difference is Nokia IC's are installed on its board or circuit board by lead balls so called BGA Balls, actually looking like its floating from the board. When the phone is subjected to water, water seeps through and inside these lead balls, rushing in between the IC and the main board, and never leave there, nor the water will dry. One should really dry it out using special solvents and a "HOT AIR" gun.
From the time you re-installed the battery back, you actually induced short circuiting because some, or all IC's have water in between them and the board. Here is a picture of it for you to understand, notice the "BALLS" of lead, and the empty spaces in between them, chiefmecha.gif
So i guess you have done harm again by subjecting short circuiting on the phone. I therfore suggest you bring it in at any NOKIA care center for repairs, You wont be able to fix that by yourself, for the phone now may have damages to any IC's thats why it shuts itslef off, and never charges, NOKIA high end phones have a certain defense mechanism to turn itself off when triggered with water damage.(again refer to the picture)As you can see there are many IC that could be any or all of them are now damaged.
Hope this clears your questions, and I highly suggest that you remove the batteries now, and never attempt to power it and/or charge it until it is looked upon by a certified Tech.
Thank you for using Fixya.
Jan 12, 2011 | Nokia X3 Cell Phone
Motorola e398 insert sim problem
insert sim truss gan pdahal sy sudah ganti sim nya nih
Feb 26, 2010 | Motorola Mobility E398 Cellular Phone
Can't open the phonebook of my motorola e398
Motorola E398/Razr address book disappears/bounces:--Solution
press 1+# (i.e. speed dial #1)
press Menu -> Categories -> Select -> All
Bingo. U r now in the Address Book --delete all entries which have no names against names or add some name.
Dec 11, 2008 | Motorola Mobility E398 Cellular Phone
Recovery of motorola e398 with dead flash...
download rsdlite 3.9 and flash motorola e398 and ok for flash.
Jun 20, 2008 | Cell Phones
Motorola e398
how can i format my motorola e398
May 06, 2008 | Motorola Mobility E398 Cellular Phone
Fast battery drain only 6 hours standby (new battery)
i think some of the motorola mobile phones has a fast battery drain..
Feb 24, 2008 | Motorola Mobility E398 Cellular Phone
Themes
here's the perfect solution :) Go to www.zedge.net insert your mobile type motorola E398 and enjoy millions and millions of BEAUTIFUL themes Hope i helped :)
Jan 28, 2008 | Motorola Mobility E398 Cellular Phone
Motorola Mobility E398 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
