RGB NO INPUT SIGNAL - Computers & Internet
  • 4 more comments
  • SHAUNMURTON Jul 12, 2008
    JUST TRIED THIS - WHEN I UN PLUG THE 15 PIN CABLE THE SCREEN SAYS - SIGNAL CABLE DISCONECT! AND WHEN I PLUG IT BACK IN THE MASSAGE COMES UP WITH RGB NO INPUT SIGNAL AND THEN GOES OFF AFTER A COUPLE OF SECOND WITH THE MONITOR BLANK AND IT GOES INTO STANDBY MODE ( THE MONITOR )
  • SHAUNMURTON Jul 13, 2008
    LCD MONITOR MODEL: F159 INPUT 100-240v 50/60HZ 1.0A
    (DIXONS)
  • bumpscott May 02, 2009
    i switch my pc on and it comes up with no rgb signal then goes to standby can you tell me why and how to solve it please
  • Anonymous May 04, 2009
    i have exactly the same problem, just cant seem to be able to do anything about it
  • Anonymous May 06, 2009
    my computer just shuts off and then after getting back a signal comes up with no rgb signal then it cuts off again
  • Anonymous May 26, 2009
    The PC turns on and beeps. and the screen turns on. after about 2 seconds the screen goes black with the message "RGB no input signal" ive checked all the plugs and nothing is loose or missing.
  • 1,498 Answers
RGB stands for Red Green Blue. Your monitor isn't getting a video signal.
First, look behind your PC.
Pull the video plug and check the pins.
The should be three rows of them. Make sure none of them are bent over.
On the back of the PC, look at the connector socket you just pulled the plug out of. Is there another like it? (15 holes, 3 rows of 5)
If so and the original doesn't work, switch the plug to the other.
Put the plug back in and screw it in tight.
Reboot your PC.
Hope this helps,
Mike
Posted on Jul 12, 2008
  • Justin Case
    Justin Case Jul 12, 2008
    Does your monitor have a multiple input option?
    Look at the back of the monitor:
    - Is there a row of five BNC (coax half twist) connectors?
    - Or a second VGA (3 rows of 5) connector?
    If so, there should be an input select either a button or on a menu.
    - If there is just a single cable coming out of the back - then no.
    Back to the VGA connector in the back of your PC.
    Is it a separate VGA card or part of the motherboard?
    If it's a card, it may be loose. Did you notice any play in it when you plugged the monitor back in?
    Some testing:
    If you have a second PC and or monitor, you could run a few tests to locate the problem.
    Try your monitor on a different PC.
    If it works, the problem is in your PC.
    • A loose card - Needs to be reseated.
    • A bad card - Needs to be replaced
    • Built in VGA may be fried - New VGA card
    Try a different monitor on your PC
    If it works:
    Your monitor is the problem, most likely in the cable somewhere. Hard to find, hard to fix. If it's under warranty, exchange it. otherwise replace it.
    To be thorough, can you let me know the monitors make/model?
    Hope this helped
    Mike
    New Friend:
  • 35 Answers
If you have a Vizio TV/Monitor (such as the VO22L, etc), try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote (could also be done while in TV mode, if you can't get the monitor to stay on in PC/RGB mode). The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". Power the monitor off and on, and the problem should be gone..
Posted on Aug 01, 2009
2 Suggested Answers
  • 11800 Answers
SOURCE: rgb no input signal computor
Have you tried to disable the Power settings? For that go to Start, Control Panel, Power Options and in there put everything to Never, click Apply and OK.
If it happens even after that then the video chip is dying and it will have to be replaced - you will need a new video card.
Posted on Jun 18, 2011
Reset my Sanyo tv so that it recognizes the rgb input
RGB is for a computer, unless you had one hooked up it would say no input.
Oct 14, 2016 | Sanyo Televison & Video
Rgb no input signal computor stars up on for a few mins then goes blank and a sign saying rgb no input signal
Jun 17, 2011 | Computers & Internet
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Pc to tv
Try changing the resolution on you computer. That TV may not handle the current resolution setting. You may also have to do something on your computer to turn on the rgb output.
Feb 22, 2008 | LG 42LC2D 42 in. LCD HDTV
Computers & Internet Logo
8,815 people viewed this question
David Payne
David Payne
