Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
Loaded the front load washer pretty full and heard a scrubbing sound as the tub begain to turn during the wash cycle. After that, the tub stopped moving although the washer contined to go through the cycling. Sounds like the washer is signaling but the tub does not agitate, spin or move at all. Please help. Thanks!
What a bogus website you are. you offer no free support and you should say so
Posted on Jul 13, 2008
Turn off beeping bosch wfl 2060
All you need to open the control panel and remove the connection to the buzzer unit.
If the washer works fine , the buzzer can be disconnected
Jul 03, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Vibration on spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
Dec 14, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Over loaded the washer and now the door won't open
lynn903:
If you turn the knob to "Drain" the door should open.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Filter
if you have a foreign object in the washer, this can not be removed by checking the filter
remove the heater and you can see into the gap between drum and tub and remove whatever is there
Jul 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 front load
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Dec 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
274 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
