Epsom salts are the only thing that makes a difference tried all the new gear doesnt work as good as epsom salts every two weeks 1/2 cup on hot wash with no clothes & use cold power advanced washing powder this is the best way of keeping control of it once you get it clean you have to keep on top of it the smell doesnt take long to come back with out continues treatment.
In a pitcher, mix 1/2 white distilled vinegar, and 1/2 hot water. Add two teaspoons of blue Dawn dish soap. Sprinkle a decent amount of baking soda in the bottom of the washer tub, pour the pitcher over the baking soda it will bubble up. Make sure all of the baking soda gets the solution poured on it. Then run a cycle through with no clothes in it. That will clean the tub and drain line, & help with the smell and the mold. You also mentioned that it came from a rainwater tank, the line running from the tank to the washer may need to be cleaned out with the same solution. I hope this helps
The water pressure must be good and the spraying must be seen to be
good. If there is low pumping or pressure then the spray arms will not turn
around to inject with pressure which can result in poor washing and leaving of specks. If so
the pump must be checked for clogging.
To replace
check this link:
