Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
It stopped last evening and is flashing what looks like FE
Your water tank is full. Unplug upper and lower hoses, empty into jar and throw away water. RePlug and good to go...
Posted on Jan 19, 2009
FE 20 turn off flash
Look for the flash button (looks like a lightning bolt) to cycle through the flash options. Flash options can be limited in AUTO Shoot mode.
The manual describes how to use the Flash on page 19 of the manual.
You can download the manual here http://www.olympusamerica.com/files/oima_cckb/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
Mar 13, 2011 | Olympus FE-20 Digital Camera
How do i stop the flash popping up on a canon eos 350d even when taking a photo outside in bright light...I am using the auto setting
Try using the "no flash" setting. It is still completely auto, it just won't fire a flash. It is the setting that looks like boxy "no sign" over a lighting blot on the settings dial, it is also the last setting.
Hope this helps!
Oct 19, 2010 | Canon Rebel XT / EOS 350D Digital Camera
What is the interval for changing oil on my 2003 santa fe gls hyundai
best way to find out is look in your owners manual it will tell you. 5000 miles is a newer standerd now days. if it was even newer it would be even longer more like 7500 to 10,000. but your is a little older so im going to go with 5000. but check your book. it also has alot of important info .
Sep 16, 2010 | 2003 Hyundai Santa Fe
The flash does not work even if the flash setting is SET to FILL ( the flash will work every time the camera is in used) I already tried to reset the settings to default but still the flash wont...
Does the camera indicate that the flash is turned on? In most olympus cameras I have seen there is a lightning blot at the lower left corner of the screen. Verify that it is indeed there and let me know.
Aug 18, 2010 | Olympus FE-170 Digital Camera
My fe 230 battery doesn't last long
Unfortunately, all digital cameras with zoom and flash eat up batteries pretty fast. The best thing you can do is buy backup batteries, and have them when you have some serious shooting to do. Also, rechargeable batteries don't last forever, and start losing energy after awhile. You can order batteries at a great price by shopping on ebay. Good luck!
Mar 14, 2010 | Olympus FE-230 Digital Camera
Fe-310, only used a few times, kept protected, one
Short answer - yes.
Manufacturers have become very good at making products that are reliable for exactly 1 year.
Usually it's small components that have a deffinate shelf life.
I would first check that you are using the correct battery for it. Even if it looks like it takes standard AA's - they often will only work for original spec rechargable blocks.
If this does not solve it - write a letter to Olympus saying how dissapointed you are with their product.
They may offer you a good deal on a repair hopefully.
Unfortunately Sony and HP are even worse - HP and lexmark printers now stop working after a period of time - telling you to buy more ink - even though you still have plenty.
Oct 01, 2009 | Olympus FE-310 Digital Camera
Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Dec 28, 2008 | Olympus FE-140 Digital Camera
There appears to be a loose connection . The camera stops working
i have an olympus fe-100 even with a new battry when swith on the lens move out & back in , then two light green & orange flash 10 times & stop
Nov 17, 2008 | Olympus FE-100 Digital Camera
Flash not working
The flash tube or the circuit could be burned out as it is fairly high voltage.
if the tube is black then its blown
Mar 11, 2008 | Olympus FE-230 Digital Camera
Heating & Cooling Logo
294 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
