Question about Acme 5001 Supreme Juicerator Juice Extractor
Cleaning How do you get the pulp out after juicing. There does not seem to be any way to open to clean. My juicer does not have the 5001 just ACME
Http://www.smallappliance.com/product.asp?pid=9879&cur=USD&sid=18956&mid=34&gid=18975&prdCls=P&shopBy=Category
Posted on Oct 13, 2008
    Problem Solver:
  • 5 Answers
Are you unscrewing the post in the middle so the basket and shredder blade can be removed
Posted on Apr 09, 2009
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
When i juice greens i am no longer getting any juice from them. is my blade dull?
If you mean green leafy greens, the juicer is
not really designed for them. A sharp blade
will extract some juice from them, but I found
a new blade seems to increase the vibration
issue. Acme works best on carrots, apples,
celery, etc.
Oct 25, 2010 | Acme 5001 Supreme Juicerator Juice...
Cleaning after juicing
It's easy. Scoop out the pulp with your hand and
then under running warm water sponge the outside
first and mop up the inside next. Keep rotating the
basket as you clean. If the juicer becomes discolored
after a while, boil the parts in a solution of Oxi Clean
and water, then scrub. She will look like new.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
Sep 02, 2010 | Acme 5001 Supreme Juicerator Juice...
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
The 6001 vabrated so much the top came off and the flang bent.
WARING AT 800 492 7464 HANDLES ACME
JUICERS. VIBRATION MAY NOT INDICATE
REPAIR. THIS JUICER DOES NOT EJECT
PULP SO IS PRONE TO VIBRATION JUST
LIKE AN INCORRECTLY LOADED WASHING
MACHINE. HOWEVER, SEVERE VIBRATION
WILL CAUSE THE BLADE TO CHEW UP THE
CHUTE. YOU WILL NEED A NEW COVER.
TALK TO WARING. ANOTHER PROBLEM
IS NEW COVER PROVIDED WILL NOT FIT
SOME OLDER JUICERS WITHOUT FILING
DOWN THE EDGE OF THE COVER. TAKES
TIME BUT CAN BE DONE.
Jun 24, 2009 | Acme 5001 Supreme Juicerator Juice...
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme Supreme Juicerator 6001 Model # 11JE21
REMOVE THE COVER BY ROTATING AND
THE CLUTCH NUT HOLDING DOWN THE
CUTTING BLADE. EVERYTHING LIFTS OFF.
CLEAN ALL DISCOLORED PARTS BY FIRST
BOILING IN A SOLUTION OF OXI CLEAN AND
WATER, THEN SCRUB WITH A SAFE
ABRASIVE SPONGE. SHE WILL SHINE UP
NICE.
Feb 14, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
202 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
