Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark X5495 can't scan, Downloading application list
I recently bought Lexmark X5495 all in one printer, Message shows up on lcd:Downloading Application List then says Cannot Retrieve. Ive ticked it as an exception in the firewall settings, that hasn't helped, reinstalled the driver, that hasn't helped. I can still print, receive faxes etc. The problem comes in when I try to scan, and this is the ONLY reason I bought the machine. Lexmark South Africa, says they've never encountered the problem before... what now?
  • 10 more comments
  • hmmblahu Sep 18, 2008
    i have the same exact problem with my Lexmark [X5495] all-in-1. i can do everything BUT scan, i get this message saying it cannot retreive application list. the ppl in india say they canont do anything about it:[
  • ciaran-cor Nov 16, 2008
    I try to scan my document and it comes up on the printer cannot retrive application
  • dodgers1132 Nov 27, 2008
    when i try to use the scan on the all in one it says"cannot retrieve application list" and i don't know how to fix it
  • japss Dec 17, 2008
    Cannot retrieve application list.
  • Anonymous Dec 19, 2008
    i have the same problem and this solution douesn't help (i'm sorry to say) please help
  • MrsSnyder Dec 27, 2008
    I have a Lexmark X5470 all in one printer.Everything works on it but the scanner.When I try to use it, a message comes up that says "Cannot Retrieve Application List".
  • Anonymous Jan 21, 2009
    same here
  • Anonymous Mar 19, 2009
    i can print copy fax but cannot scan downloading application cannot retrieve
  • urbuttonlint Mar 29, 2009
    I have the Lexmark 5495 all-in-one and when I try to scan it says downloading application list. Then after a couple of minutes it says cannot retrieve application list. My firewall is off.
  • Anonymous Mar 31, 2009
    Lexmark's support site is useless.
  • Anonymous Apr 11, 2009
    Responds as printer but will not scan- keep getting "Downloading application list or cannot retrieve application list
  • Anonymous Apr 23, 2009
    i have the same issue
I had the same problem with my 4550 model. Lexmark now has two patches available (search their support database for "Cannot Retrieve Application List". The patches appear to be a batch file that replaces a file in the install directory. Once I applied both patches (document says you may only need the first) I was able to get it to work if I turned "off" the firewall. When the firewall is turned back on then "Cannot Retrieve...". Before applying the patches, turning off the firewall did not help.
Now that it works it's very cool. I select the system on the network, it shows me the application, I press color or BW, walk over to the computer and the application is open with the scanned image. Cool, yes - getting it to work was a major task of continuously searching the net for help.
Posted on Aug 04, 2008
If you Turn off the firewall at all( just to test), the scanner still not working? I had the same problem(Cannot retrieve list) Turn off firewall and, voila, it works very well. Now I have to find out which port/program in the exception list should be supplied.
Posted on Jan 27, 2009
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
864
Posted on Mar 02, 2009
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X4580 (all in one wireless)
HI,
You can try out these two options one by one to fix it up:
A)
1 Unplug the printer.
2. Uninstall the drivers.
3. Reboot the machine.
4. Go to the lexmark site and download the drivers.
5. Install the new drivers.
B)You will get the "CANNOT RETRIEVE APPLICATION LIST" if your pc blocks the communication from the printer. This can be configured in your personal firewall. This can be Windows Firewall (found in Control Panel, Security Center), Symantec Client Firewall or similar. Depending on the configuration of this firewall you might or might not get pop-up messages from the firewall during installation. These pop-ups will allow you to permanently allow for this incoming communication. But your firewall might be set not to let you decide anything which will typically mean that the calls will be blocked out. This will often be the case if you have a company laptop configured by the company IT dept. You might then have to ask an admin to add exceptions the applications used by Lexmark as the configuration might not be open for you to change.
I think this is the complete list of applications:
Job Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdijswx.exe
Lexmark Communications System: C:\WINDOWS\SYSTEM32\lxdicoms.exe
Lexmark Connect Time Executable: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxditime.exe
Lexmark Device Monitor: C:\Program Files\Lexmark 3500-4500 Series\lxdiamon.exe
Lexmark Imaging Studio: C:\Program Files\Lexmark 3500-4500 Series\App4R.exe
Printer Communication System: C:\WINDOWS\SYSTEM32\lxdicfg.exe
Printer Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdipswx.exe
Goodluck,
Please don't forget to rate the solution.
Apr 17, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Impact s305 printer won't scan. it's stuck on "downloading application list"
Try using the Lexmark Printer Home when scanning. If you have a PC, to access it click on Start > All Programs > Lexmark > Printer Home. You can scan to a .jpeg, PDF or .doc.
If you're scanning from the control panel of your printer and you're getting an error message, "Cannot Retrieve Application List", most probably your firewall is blocking your printer from downloading the applications. You might want to add the Lexmark files in the exception of your firewall. Click on the link on how to add exceptions to your firewall.
If you're trying to scan to email (email client), try to check this link: http://bit.ly/k0w0Hp
Mar 11, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
My new Lexmark X5650 doesn't scan to computer. Each time I try it shows the message "Downloading Application List." The it shows "Application Acrobat Reader." After a while it goes to sleep, but doesn't...
I had my phone turn off,but can still use my computer on line,and now my three in one printer is saying downloading application and then it say can not retrive.
Dec 22, 2009 | Lexmark X5650 All-in-One InkJet Printer
Unable to scan
scan from within the software that you're going to use to edit the file.
Jan 01, 2009 | Lexmark Office Equipment & Supplies
Device monitor application problem
Make sure that the Lexmark Imaging Studio program is running. This was installed when you set up your printer.
If you see the multi-colored icon in your task bar for Lexmark Imaging Studio then try pressing the scan mode button twice. You should be able to scan then.
Sep 28, 2008 | Lexmark X3550 All-In-One Printer
Can not scan
uninstall the drivers and utilities, then reinstall from lexmark website.
Mar 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
8,098 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
