Question about Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop
Starting machine Hi machine will boot, psu seems to be ok getting power to mother board. machine just does nothing when I press power on.
Mine did this, there is a small round battery (size CR2032), try replacing that, I did on mine and then when I preseed the button it started working again!
Posted on Jul 14, 2008
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Hi: no power from supply opened box and checked fuse - its ok! The computer had a virus and that was fixed restarted computer and it worked ok, the next day pressed start button and nothing happened....
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 20, 2011 | Dell 250W POWER SUPPLY NPS-250KB...
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Can not get the MB to power up. The PS seems to
to boot you will require
mother board
graphics of some kind
cpu
ram
psu
if nothing at all happens and there are no lights you should probably make the psu the first thing to test/replace
Oct 13, 2009 | MSI MS-6580 Motherboard
My computer is switching on and nothing displays in the monitor. After switching on, after a minute it automatically switch off. Mother board is Intel 845 GVSR processor 2.4 GHz. Service centre person is...
Try a bios reset first.
Second pull out the memories (RAM). If you hear beeps on startup the the motherboard and the processor is ok.
If not, possibly could be the processor.
Also try with other power source.
Jul 28, 2009 | Intel Desktop Board D845GLLY Motherboard
I have a emachine PC. PowerSupply blew up. changed it still down
try to remove the memory and put it back again make sure put it fit and correctly
May 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Scaleo P Does not Start up, No Fan, No Boot Up Nothing at All
something is shorted or PSU has failed
make sure cards are seated down (with power cord out)
try if works ;) your good
if not next step is cord out an remove power and cable off the CDROM drive
try it, just go through all hardware till it starts
to determin what failed, if still same no boot then PSU has died
Apr 16, 2009 | HP Compaq Business d530 PC Desktop
Emachines W2888 will Not Start up
Most likely the system board has failed. If the power supply had blown it is not unusual for the subsequent spike to blow the system board. On the other hand it may have been the system board that failed and the PSU is ok. Emachine system boards are rubbish
Either way you will need a new board and most likely a reinstall of the OS
Dec 09, 2008 | E-Machines eMachines Desktop PC
Computer will not boot
Option 1 :
Remove completely the mother board from Cabitnet.
Try to check it on other Cabinet.
Option 2
Remove mother board and re- plug the SMPS power Connecter to Mother board outside of cabit and make sure that motherboard is not touching directly to Metal part of cabinnet.
then switch on computer and check
Nov 22, 2008 | ASUS P4S800-MX Motherboard
Wont post.
Try a few things for me OK? From what you typed, turned on the psu "the toggle switch on the psu", pc seemed to be starting up. I need you to keep the toggle switch on the power supply in the on position. Press and hold the start button on the PC case to shut it down. Give it a few seconds & power up by pressing the power switch on the case. Notice a differance? Next, unplug everything connected to the pc expect the monitor, mouse & keyboard. Try to boot. Still no? Remove the side of the case exposing the board. Turn the psu off by flipping the toggle switch on the psu, wait till the green light on the board goes out. Grab the Mb ( I know it's tight in there) and see if you can move the board in any direction. Not loose? Re-check all data & power connections for a solid connect. Re-check your case to Mb connections. Also check the PSU, there is a red slide switch it should be set to 115v. Post your findings..
map
Jan 28, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Logo
127 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
