Question about Miele Touchtronic W1113 Washing Machine
Drsining washer manually
I can't figure out how to drain my washer manually. I have a Miele Touchtronic Washer W 1113. Thanks.
  • 770 Answers
Open the little door at the bottom fron and twist open the lint filter clean out
Posted on Aug 20, 2008
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele Touchtronic W1213 Front Load Washer: The washer keeps adding and then draining water continuously. One time, the cycle ended and the machine continued to add water and drain endlessly....until I...
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
May 17, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele washer leaking from soap tray (on rinse cycle). Can't figure out what's the problem. Please help.
Remove and clean fully soap tray. if persists could be machine leveling or water pressure too high going in so fast to tray that its unable to cope, in which case try reducing the water pressure. good luck
Feb 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Miele frong load washer water will not drain, what do I do
Check the hose going to and from your pump which is located on the bottom of your machine. You prob ably have a underwire preventing ytour pump from spinning.
Jan 14, 2010 | Miele Touchtronic W1213 Front Load Washer
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Miele Touchtronic W1113 Washing Machine Logo
275 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
