Question about 2wire 2700HG-B Router (2700HGB)
Modem keep rebooting.
I have this problem. When you restart the modem, you'll expect to see a green light under the Power. However, mine does different. A red light will appear and a ticking sound will be heard. It will keep ticking until it turns green and then it starts blinking. When it stabilised, it will restart again after a few seconds. Before this problem, I cannot get connected to the internet. It shows a red light under the "internet." Please help. Thanks.
    Scholar:
  • 43 Answers
It sounds like you have a bad modem. Have you tried to plug the device into a different power outlet? This will rule out that it's a possible power issue in the outlet.
If no change by trying a different outlet I would replace modem.
Hope this helps.
MO
Posted on Jul 13, 2008
D-Link Router, Model DI-524 is not able to register IP address. My cable company did maintenance yesterday and this morning unable to link to internet with Router hooked up to modem. Apparently no good...
Sometimes when ISP's do maintenance the DHCP servers re-assign new IP numbers. When you have symptoms like yours it's because the modem, router, and computer are working off previously assigned old IP numbers that may have then been re-assigned to other customers modems after the maintenance. Same with the router. Rebooting your equipment causes them to pull new IP numbers and things start working again.
So, usually a reboot will fix it. Turn off the computer(s). Turn off or unplug the power cables from both the modem and the router. Keep them off for 3 or 4 minutes. Leave the data cables connected. Plug the power to the modem back in FIRST. Give it a few minutes to come up. Any lights should be green. If the lights don't come up green on the modem you'll need to call the cable company.
Second, plug in the router and let it come up. Again, lights should be green. Lastly, turn on the computer.
That should do it. If not, please post back. There are other things to try.
Jan 13, 2011 | D-Link AirPlus DI-524 Wireless Router
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
I am trying to hook up to my new comp. and new internet and the lights come on for the wireless, wired and router r green then the modem light is red, what am i doing wrong
There is nothing wrong with your modem. There are modems that when you turn it on, the wireless, dsl lights are green while the power light is red then after a few seconds, the green lights disappear and the red light will turn green. After sometime green light will come back on. This means your modem is restarting and doing a self check.
If the power light stays red, then you a have a problem with your modem.
Sep 10, 2010 | Computers & Internet
My D-Link modem( DCM-202) keeps restarting itself, when I scan the internet for different articles, and when this happens I get no photos and only a part of the article
This is typically Power Voltage issue, Please connect your Modem with UPS it wouldnot reboot anymore but if it still reboots, let me know
Oct 01, 2009 | D-Link (DCM-202) Modem
Power light is red on 2wire modem
this happened to me and it turned out the power cord had gone bad. i went to radio shack and bought a new one for 35.00usd and it powered right up.
Jun 26, 2009 | 2wire (1000-000057-000) Modem
Wont connect. power light is red. wireless light is green. i have a 2701hg-b 2 wire. i ve tried diconnecting, resetting, but the gateway remains the same. what do i do?
I've got the same issue, 2 wire claims that whrn the power light is red, the modem is bad and must be replaced. I would try and power the modem from another circuit before replacing. I am replacing mine today
Jun 24, 2009 | AT&T High Speed DSL Modem
Modem keeps rebooting
This problem seems to be ISP based.. I'm having the same problems last 2 days with AT&T DSL
Jul 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Internet Light keeps blinking - all others are out - No internet
HI,
Blinking green internet light is normal BUT you must check if theres any dsl outage in your area..You can contact your ISP for that.
But then maybe you can try this:
Turn your PC off > then you modem or router.. after 60 secs turn your modem or router ON first then your PC and check if you can go online.
If you called your internet service provider {ISP} and no reported outage let me know and we'l solution for that.
Keep me posted.
Cheers.
Jun 16, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
2wire modem/router keeps rebooting
ANOTHER COMMON ISSUE: If your modem keeps restarting once the power LED turns solid green, the most likely cause is the power adaptor. Replace the power adaptor and all should be well again.
Nov 27, 2007 | 2wire (1000-400108-001) Router
2wire 2700HG-B Router (2700HGB) Logo
211 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
