Question about Canon PIXMA MP160 All-In-One InkJet Printer
Speedo problems i am looking to buy a citroen synergie second hand but the dealer says its got a twitchy speedomiter the miles per hour are working though what can it be
I had the same problem. The speedo and the tacho are both stepper motors and the pointer is driven via a set of plastic gear wheels. The cogs strip and the stepper motor can not go past a cetrain point at which the pointer twitches. My solution was to strip out the console and swap the tacho and speedo gearing. If your are technically minded it is quite easy. If not, get somebody who is to do it for you. Good luck. Steve.
Posted on Dec 12, 2008
Citroen relay 2012 mileage flashing. Hands free stopped working and usb stopped working. All at the same time?
dealer only ,unlike old cars with a mw/lw radio on radio caroline and lever to work the heater and of course little numbers in the speedo head that i was good at ,,,,,,hmmm say no more
May 26, 2016 | Citroen Cars & Trucks
Roger Black JX 286 - is the distance on this treadmill measured in miles per hour or kilometres per hour?
Firstly look Via Google, for your needs, Ive found some info on the Argos website.
Dec 12, 2015 | Exercise & Fitness
How do I get a free download of owners manual for citroen synergie 2002
What do you need a manual for its a citreon for their so simple to work on any back street mechanic can work on them which is what makes them so good for the second hand market ,even the software is readable and no fancy flat key thing to wrong like a renault,brilliant car
Feb 27, 2015 | Citroen Cars & Trucks
HOW USE TACHYMETER & WHAT TACHYME3TER MEANS
A Tachymeter helps you estimate the speed you are going.
It uses the basic formula that speed = Distance/time
Here is how to use it: (For the full article see the link below)
To use tachymeter, simply start the chronograph or stopwatch when the object measured passing the starting line. When the object reaches the next mile or kilometer marker, stop the chronograph or stopwatch. The point on the tachymeter scale that adjacent to the second hand of the watch indicating the speed (in miles per hour or kilometers per hour) of object traveling between the two points.
For example, we want to measure the average speed of a vehicle is moving. Start the chronometer or stopwatch function when the car passes the starting line, and stop the timer after the vehicle traveled exactly 1 mile or 1 kilometer. Then look at where the chronometer hand (the second hand of the watch) is pointing to, and get the reading or value of the corresponding number at the tachymeter bezel or dial. Let's say the stopwatch stop at 3 o'clock position, meaning 15 seconds had elapsed for the car to travel 1 mile or 1 kilometer. At 3 o'clock position, the tachymetre value shows that number of 240, which means the average speed of the vehicle was 240 mph or km/h.
Source(s):
http://www.mydigitallife.info/2006/12/10...
Apr 02, 2013 | DKNY NY5045 Watch for Men
Dodge avenger speedo sticks and doesnt seem to shift correctly after speedo sticks
Sticks? Where? Zero miles per hour, or a value above that? The problem is likely the speedo "head", the part immediately behind the speedometer that makes it work. And if the speedo is not working right, the trans will not either. It might be worthwhile to have it "scanned" to see if the computer can identify the cause of the fault.
Apr 18, 2011 | Dodge Avenger Cars & Trucks
I JUST GOT A 2007 SUZUKI BURGMAN 400 from Wisconsin with 2900 miles on it and found out that it cannot be registered until it has 7500 miles on it.Apparently it is a ( 49 state ) bike and California isnt...
You could buy a second hand speedo from a bike breakers, I would never suggest you try tampering with the odometer, the way dodgy used dealers may remove some miles.
May 01, 2010 | 2003 Suzuki AN 400 Burgman
Reads 40 TO 45 miles per hour but I know I am going faster and sometimes it will drop to 0 miles per hour.
A place in Flint Michigan will repair this problem (speedo motor) for 100.00 and will replace all the other motors associated with your dash instruments. Off of Hill Road Near I-75. Did my truck in 20 minutes. Works Great!!! Business called Speedometer Something.
Jan 15, 2010 | 2003 GMC Sierra
On my 2005 gt mustang the speedometer is way off it sits at 100 miles per hour when i shut the veh off and i changed the sensor on the side of the transmission that did'nt work can u help me.
it sounds like the speedo head in the instrument cluster is bad.
buy a used cluster on ebay
VSS only affects speedo when car is moving.
Dec 26, 2009 | 2005 Ford Mustang
Speedometer cable
First: you unscrew the cable housing assembly from the back of the speedomiter housing.
Second: you pull the speedomiter cable from the housing.
If the cable is broken inside the housing you must unscrew the housing from the spedomiter adaptor on the front axle,. at this point you should be able to pull the broken end from the adaptor with a pair of pliersif you can't pull it at this point you will have to pull the front axle and take the adaptor out and try to remove the broken end.
I hope this helps.
Nov 10, 2008 | Harley Davidson XL 1200 L Sporster Low...
Rear door will not open on citroen synergie, how can i get it open.
I had the same problem on 2 synergies try and bump the back of the door with your bum or shoulder i find this usually works
Jul 21, 2008 | Peugeot Liberte Cars & Trucks
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
136 people viewed this question
old marine
old marine
