Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon Printer MP160
HOw can I can dismantle this unit? I'd like clean it inside. Thanks for your help.
  • 12 Answers
Remove the cables (power and USB).
Remove the paper output tray by gently flexing the hinge tabs.
Remove the rear paper support by lifting it up and out.
Remove the front plastic panel. When you lift the scanner unit you will see 4 tabs (2 on each side at the top) which you need to depress and the panel will pop out.
Remove the side panels. Each panel is held with 3 screws at the front and 2 at the rear of the printer. Also remove the 2 screws fixing the direct print port to the left panel. The panels will come away with a bit of twisting.
Remove 2 vertical screws at the top rear corners of the scanner unit. The only things that now prevent the scanner unit being lifted clear are the cables that need to be disconnected.
Remove the screw holding a black wire to side panel (note this is a metal thread screw which is different to all the others you remove).
Unplug the 2 thin ribbon cables from the circuit board sockets by gently pulling them upwards using tweezers. Unplug the 3 other cables that plug into the circuit board. Be careful not to break anything associated with the circuit board. Make a drawing of the cable positions as they will need to be tucked and taped back into the correct places when reassembling otherwise the side panel will not fit back.
Lift off the scanner unit and set it aside.
Now that you can see inside, you can remove any foreign objects and debris and make some routine checks. Look for the large grey feed roller at the rear and slightly right of centre and clean the roller. Nearby is a delicate spring loaded black lever that interrupts a light sensor until the paper starts to feed. Check that it operates freely. Use cotton buds to remove ink that has accumulated around the areas near the print heads. In the back right corner is a large felt pad that absorbs waste ink. If it is completely saturated you may want to remove it, rinse it, dry it and replace it (this is a messy time consuming job so only do it if really necessary). To get to this pad or anything else deep in the works remove the appropriate screws. Just about everything that can now be removed is screwed to the base. I recommend making an outline drawing of the base and recording the position of any screws you remove to ensure they are all replaced before proceeding.
When you are satisfied, reassemble in the reverse order. Make sure you replace all screws and carefully reconnect all cables. Make sure the flat ribbon cables are fully in their sockets. If you have taken care and have no bits left over, you are ready to test the printer.
Posted on Jun 13, 2009
  • 22 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
mbhd6
Posted on Sep 05, 2009
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My Canon mp160 Printer doesn't print some color like brown and grey and i need help ASAP because i need to print something for school
Clean your printer head and nozzle with printer utility software. Hope it would solve your problem, if not, change black and color cartridge. Thanks.
Sep 29, 2009 | Canon PIXMA MP160 All-In-One Printer
Color ink cartridge does not print in full colors
Canon printers do not like the refilled ink cartridges. After having ruined a few printers trying to "save" money. I went back to genuine Canon ink and have never had a problem since.
Jun 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E5 error
hi try to install a new driver from here http://support-my.canon-asia.com/EN/search?canonsearch=1&lang=EN&category=Multifunctional+Printers&series=PIXMA&model=PIXMA+MP160&menu=Download otherwise ur error code means The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly. Install cartridges properly. so try to clean the cartridge pinout well by using Acetone or something like that also try to clean the pinout of the cartidge mount inside the printer when it's power is off.
Jun 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper roller Problem
hi,
pow-e-r-3
Jun 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error Code 5 on Canon MP160 Printer
your problem is waste ink absorber is full,you need the canon mp tool which is use to reset the counter of your printer,but you must dismantle your printer to clean the waste absorber because if you will reset the counter without cleaning it, all waste ink will overflow on your printer.
Apr 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP160 error 27
My canon pixma mp 160 printer/ scanner is showing E 27, ink absorber is full need help please.
Jul 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
299 people viewed this question
old marine
old marine
