SMC Barricade g SMC2804WBRP-G Wireless Router Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I Change from WPA to WEP key on my router?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 240 Answers
  • Posted on Jan 10, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
240
Questions
0
Helped
60830
Points
736
Hi. Thanks for your question.
Please see my tutorial on how to change your password on your router------> http://www.fixya.com/support/r4695161-change_wireless_network_password_forgott
If you do know current password please skip the part about the cable and continue with wireless connection.
Thank You for using FixYa.
I can't find my WEP Key
you can get your WEP by logging to your router via cat 5 cable.
open internet explorer
browse to http://192.168.1.1
default login is blank password is admin
click on wireless click on wireless security
WEP passphase is displayed.
i highly recommend you change WEP to WPA. WPA is much more secured to WEP.
1helpful
I need help getting our network key for our wireless router...
What is the model number of your dlink router?
anyway, just go to your hardwired computer:
Hardwired computer:
1. open web browser
2.in the address bar typein 192.168.0.1
3. the username:admin password:(None, just leave it blank)
4. Click "SETUP"
5.Click "WIRELESS SETTING"
6.Click "MANUAL WIRELESS NETWORK SETUP"
7.change now the SSID or NETWORK NAME (create a new name to avoid conflicts with your ol network name that was saved into your computer
8.Look for security mode, Select WEP or WPA-Personnal
if WEP select 10 number as a password
if WPA-Personnal, minimum of 8 Characters
9. type in the network key
for WEP type it in WEP KEY 1 (PLEASE DONNT CHANGE key 2,3,4)
for WPA-PERSONAL type it in PRESHARED KEY at the buttom.
10. then click on save settings on the top
Thats it.....
hope this will help you
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Is the PIN on the bottom of the router the same as the WEP or WPA?
WEP or WPA are the types of wireless security. If your wireless network is secured then there will be a password on the network that is called as wireless network key or passphrase ( WEP or WPA key ). PIN number is different than WEP or WPA.
To check the wireless network key ( WEP / WPA) you will need to access the router settings page.
On that page , you will find all the settings of the router.
Can I update?change the WEP encryption to WPA on my BenQ 5100U if so how do I do it
You can change the wireless security (key) from WEP to WPA from the Router only.
Login to the Router and change it from Wireless Settings option.
Good Luck!!!!!!!!!!!!!!!!
1helpful
2answers
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
4answers
1helpful
Archos 704 WPA/WEP
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Top SMC Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
