Question about Roomba Robotic Floor Bagless Vacuum
Roomba Discovery wiggles back and forth and turns over and over
My 8 month old Roomba Discovery has just started moving forward and "wiggling" back and forth in the middle of the room when you turn it on, goes about 2 feet, then turns and wiggles back to where it started 2' away. Wheels are cleared of hair, etc, blew it out with compressed air for dust on sensors, etc. It still responds to the bumber, turns 45 degrees or so then starts wiggling again. Any ideas?
  • 2 more comments
  • suewooley Jul 15, 2008
    I'm having the same problem. My Roomba acts like it's hitting obstacles when nothing is there. It backs up a few inches and then goes forward a few inches and then does the same thing again and again.
  • bobfiala
    bobfiala Nov 14, 2008
    Mine did the same thing, just before the brushes stopped turning. No amount of cleaning, including compressed air, would help.
  • dcbetjes Jan 03, 2009
    Same problem with mine, 8 months old also!!!
    Does not want to do anything else but jerkingly going back and forth!!
    Please help!!!!!
  • tivolo Jan 13, 2009
    Same thing here with my Discovery. I've thoroughly cleaned the sensors and brushes but nothing has helped. It goes forward a few inches, backs up, spins, repeats... basically staying in one spot. Unfortunately, it's out of warranty so it's just a doorstop now.
  • 4 Answers
No matter your model Roomba, this occurs when Roomba has gone "crazy." Its brain is no longer working properly and you can usually tell this when you've cleaned the dickens out of it a few times and the behavior is still the same. There's only one possible user fix and that is to take out the battery, hold down the power button for 20-30 seconds then reinsert the battery.
If that doesn't do the trick, IRobot might send you something called an Ozmo which you put in the data port to rewrite Roomba's brain. Unfortunately this requires it to be under warranty unless you get lucky. Good luck, all!
Posted on Jan 27, 2009
In the Roomba service manual it says that this is the result of a wheel drop switch problem - it may have failed (replace), worked loose (fix with hot-melt glue) or be dirty (clean with alcohol and blow dry). However I got the same symptoms on my Roomba Sage and the problem was that only one side of the brush guard had clicked back into place after I had cleaned the brush and roller. The other side projected down just enough to trigger the wheel drop switch. An easy fix, which makes a nice change!
Posted on Feb 27, 2013
  • peter549 Feb 27, 2013
My iRobot Roomba 780 just won't start moving to do the cleaning. When I press the CLEAN button it moves back from the dock, turns 180?, and then moves forward about an inch and makes the uh-oh sound...
make sure all virtual wall lighthouses are turned off. Your Roomba may be getting a signal to not proceed if the lighthouses are turned ON and facing the Roomba
Feb 22, 2014 | Roomba 780 Robotic Vacuum
Roomba is dancing?
You are stuck on spot clean. Try removing the battery and reset it then try Full clean.
Feb 14, 2010 | iRobot 4160 Roomba Robotic Vacuum
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
My roomba discovery will not operate on the clean or max buttons, will do the spot clean and goes forward then circles. Turns itself off and plays a little da do da do do do do. I have emptied tray,...
If your Roomba goes "uh-oh", beep-beep-beep, that's a 3-beep error code, indicating that your vacuum motor is stalled. Remove the grill from the outside (back) of the dustbin and make sure that the impeller (looks like a fan) turns easily and is not clogged with dirt. Then try to run the robot with the bin ON but the grill OFF. You should be able to tell whether the vacuum impeller is spinning. If not, you'll need a new bin. You can confirm wth customer support by calling 1-877-855-8593.
Jul 16, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
My Roomba Discovery doesn't appear to hold a charge
cor2an,
That sounds like a classic battery failure in the Roomba discovery series. There are sensors inside the battery pack that go bad too. Either way...it's not very practical to repair the battery....the best shot you have would be to order a replacement battery. You just pop the old one out and then put the new one in.
They are available from iRobot for $69 at this link: http://store.irobot.com/product/index.jsp?productId=2799714&cp=2804606.3358509&ab=CMS_AccSuper_Roomba400_102308&parentPage=family
There are sources of less expensive (about $35) Genuine iRobot quality batteries also. You could try www.RoboticVacParts.com at this link: http://cgi.ebay.com/OEM-iRobot-APS-battery-Roomba-400-4XXX-Discovery_W0QQitemZ270412120603QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef5d1821b&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Jun 21, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Dont move forward.
Blow out the unit with compressed air, particularly around the wheels and under the bumper. Tap the bumper with your hand.
If your Roomba stops and beeps at you, count the beeps AFTER the initial "uh-oh" tone. Then call customer support (1-877-855-8593) for assistance.
Good luck.
May 29, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
I robot won't go forward
Apache Server at www.youtube.com Port 80
The roomba moves forward about a foot then spins & 4 beeps
Mine used to buck and spin and then stop. Don't know if this will work, but it did for me. Before turning my Roomba on, I hold it on the floor and move it back and forth a few times so that the wheels spin. This seems to break up the initial resistance in the wheels and it solved my problem. Good luck.
wormelo
Jan 23, 2009 | Roomba Robotic Floor Bagless Vacuum
IRobot Roomba Discovery not moving across room.
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Sep 26, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Discovery
I had the same back-up, turn, move forward a couple inches, backup-up, etc. problem. Try cleaning/cutting the hair, etc. out from around the brushes, as well as around the ends of the brushes. Also, try a Q-tip to clean out the four pair of sensors (on my Roomba there are four pairs of little lenses under the bottom of the bumper) that (apparently) can cause the Roomba to think it is going over a cliff so it backs up. I didn't have a can of compressed air, so I turned it over on the grass and went after it with a leaf blower..up close. Lots of dust came out and it has worked fine since.
Sep 17, 2007 | Roomba Robotic Floor Bagless Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
1,670 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
