Question about StarTech.com StarView SV211K 2-port KVM Switch
I have two channels that are no longer working for viewing ZeeTV and ZeeCinema
Have you tried deleting all the channels and finding them again then put the code in and they should work frm umesh x
    Champion:
  • 258 Answers
July 19th new
00 75 4A 66 04 CF 7F 55 F3
Posted on Jul 19, 2008
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Jan 23, 2018 | Emerson EWC1303 13 in. TV/VCR Combo
TV no longer will find channel 3. The lowest channel number is now Cannel 4. My DTV box works on channel 3 and it no longer works with the TV
If you re using 'autoscan' on your TV to find channel three and it doesn't find it, the converter may not be supplying any signal for it to find.
Try using manual setting of channel three and you will see if there is any signal available. If you don't know how to manually select a channel, try the box with another set.
Mar 07, 2011 | Zenith TVA1321 Combo
My girlfriend has a toshiba 32rv530u TV. when she first connected it to her time warner cable everything worked fine. since then time warner has added free hd channels for the local commercial stations...
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Feb 06, 2011 | Toshiba REGZA 32RV530U LCD TV
Hi all, i have a problem with my vcr nv-sj500 it can't find all the channels ... it's shows only a few of them.. i'll tried to do search in the settings but still it is find the same channels but not all...
If you can find the factory reset do so and then retune. Some video's remember the previous stations and don't delete them, even if no longer there.
Dec 08, 2010 | Panasonic NV-SJ500 VHS VCR
I now cant get bbc 1,2 ,3, on my free view box it wont tune in
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 12, 2009 | Televison & Video
Bbc1 bbc2 have been deleted after retune why
Nov 08, 2009 | Panasonic TX-28DK2 TV
Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
Jan 19, 2009 | Emerson EWF2004 20" TV
Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Jan 17, 2009 | Mitsubishi CS-31505* TV
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
StarTech.com StarView SV211K 2-port KVM Switch Logo
26 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
