Question about Toshiba 27A44 27" TV
Toshiba 27AF44 horizontal deflection problem
I have a Toshiba 27AF44 television in which the horizontal size has shrunk by about 2 inches on both the left and right sides of the screen. The TV works fine otherize. There do not seem to be any horizontal sweep (size) adjustments externally like with old TV's or computer monitors. How is this adjustment made (I am not affraid to do the work myself if I know which adjustments to make)?
    Genius:
  • Toshiba Master
  • 1,689 Answers
This type of thing is not an adjustment.
If you have any type of device that has been working properly and then it shows a change of performance, the last thing to touch is an adjustment. What you have to do is find the source of the problem and change whatever parts that are causing the failure or performance change.
In the case of your TV set, there are some components in the horizontal output stage that have changed in their specifications. This happens over time with use, age, and heat.
An experienced TV service tech can go in to the circuit areas using the proper instrumentation and troubleshoot to determine the failed parts. Then he can change them for you.
It would be best to find a service center that is experienced with, or better who is authorized to service them manufacture type of TV you have. The will have access to the service manuals and the source for the parts.
This type of problem is common caused by failing capacitors, and or the fly-back assembly, and on rare occasions the deflection yoke having some type of failure. I have also seen fault conditions in the main power supply causing this type of fault.
When you give your set out for service, it would be best to ask for an estimate. Depending on the nature of the failure, the cost can be on the expensive side.
Personally, I would be seriously considering to get an LCD HDTV the way things are going now rather than putting in a few hundred dollars to service the TV that you have now.
The average cost for the type of fault you have can run in the area of about $140 to about $280 depending on the type of failures. This is if the parts are still available.
Jerry G.
Posted on Jul 12, 2008
Is the toshiba 27AF44 27
It is an analogue one. To get its specifications, click here.
Oct 12, 2012 | Toshiba 27AF44 27" TV
BLACK LINE
sounds like a video board died..
Apr 28, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
No vertical deflection-need schematic
follow the 2 sets of wires off the yoke. one goes to the horizontal sweep section and the other goes to the vertical. the drive ic with the metal tab is blown.that is what drives the vertical deflection. there is a few capacitors there. 1mf at 160v and .47 at 160 and 2.2mf at 50v on most sylvania sets . if the plastic on the top of the capacitor is shrunk,it is getting hot and is no good.that can cause a loss of sweep or foldover.99% of the time it is the vertical output ic that is gone.
Oct 28, 2010 | Sylvania Televison & Video
Picture shrunk to one horizontal line
Vertical fault. Check vertical deflection components. Transitor,IC, capacitor etc.
Check all power DC +supply points in TV.
Mar 31, 2010 | Televison & Video
Hi~Our toshiba 27af44 tv has white horizontal lines across the top 6" of the screen. It's been a constant problem only on this tv, not on our other one. The tv is almost 5 years old. Is it worth repairing...
you have some capacitors in the verticle circuit that are failing they would require replacement to correct this problem est 125 or so to repair
and probably still a worth while fix
but with the price wars for Holidays upon us you you may want to look and see what you can get with just a bit more money
i hopw this has helped
Nov 18, 2009 | Toshiba 27AF44 27" TV
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
Picture shrinking
HI: Well that is a good indication you have a intermittent connection in the circuit board. Its time to take it to a repair shop. He will re-solder the poor connections. You should not need parts. Good Luck.
Mar 08, 2008 | Televison & Video
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Horizontal lines on NEC plasma
Intermittent horizontal deflection
Resoldered the pins of horizontal deflection transformer
Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Geometric distortion, Pillow, and picture enlarged horizontaly
The problem was a short from GND to pin 11 inside IC301 (TDA8350Q). This pin is the output of amplifier for geometric correction signal. Replace IC301
Nov 26, 2007 | Televison & Video
Toshiba 27A44 27" TV Logo
218 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
