DVD PLAYER Thanks. I don't think that this is the problem. The DVD which plays will play with either setting on the DVD player - PAL is set as default. I have tried going back to factory default settings and that did not work either.
  • 813 Answers
Ok reset factory setting try to burn dvd if problem occer then u need to call a good technision
Posted on Jul 12, 2008
How do I change the region of a DVD from PAl to NTSC?
You should be able to change the region in the menu settings on the DVD player. Menu should come up on your televisions screen
Dec 25, 2014 | Computers & Internet
It's showing the video in a split, black and white screen
could be a pal/ntsc region code problem, either the menu setting is pal and your playing a ntsc region coded dvd or the menu is correctly set at ntsc and the dvd is pal that you are trying to play
Dave
Dec 27, 2010 | Initial IDM-1210 Portable DVD Player
My dvd player will only play black and white. I tried changing out cords. I made sure it was plugged in correctly. Nothing seems to work. I swapped out the dvd player to see if it might be the tv, the...
will you check the video settings in the menu?
look for NTSC, PAL or other versions that is right for the tv.
If there is a Automatic setting better use it.
An NTSC dvd wont play the picture well on a PAL tv set.
success
Aug 29, 2010 | Kenwood DVF-8100 DVD Player
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
Dvd player causes the tv screen to roll when trying to play a dvd. tv works finf when the player is off
Have you ensured that the dvd player settings are set to pal and that if the disc in use is an ntsc disc that the dvd is set to ouput pal60 or pseudo pal
Dec 29, 2009 | Insignia Televison & Video
My new "panasonic" dmp bd80 not support the PAL DVD format and can't play some DivX disks. Can you give some solution to solve the problem?
Check the dvd player settings. Try and switch the dvd player itself to NT instead of pal.
Some newer DVD Players also play videos in the MPEG-4 ASP video compression format (such as DivX) popular in the Internet, as well as the RMVB video compression format.
Check any settings on dvd player to switch format output, or check tv settings so it accepts all formats.
Nov 23, 2009 | Televison & Video
Overseas dvd playing in black & white instead of colour
Hi
Your DVD is in Pal mode change the system settings Thanks@!
Nov 27, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
