Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Downdraft Hello, I have had my Jennair range for 8 years and never thought to ask this question until now. Winters here in Indiana are windy and cold and the cold air comes up out of my downdraft of my Jennair. I am surprised there isn't a feature that will allow you to open and close the draft. I typically place a cloth on top of the draft to keep the cold air out. Any thoughts greatly appreciated. Thanks, Stephanie sterry1@sbcglobal.net
  • Anonymous Jan 16, 2009
    I have my 2nd JennAir range. This one is 10 years old. It is as cold
    and leaky as the 1st. We live in Wi. So, really cold here too. I liked
    my 1st one. All elec. Grill was like outside grill taste. The
    2nd, I had a repair man here 6 times in 6 months. Wouldn't heat enough
    to sear the steaks. They all said that it is hooked up correctly, draft
    is correct, but btu's aren't enough to cook properly on the grill. I
    can tell you that I have run across several people that were looking at
    this range. I discouraged them with my problems. I will never buy
    another. I also have a JennAir refrig. Will not have another of those
    again either.
    Don't know the answer to these problem appliances. Some of these companies don't want to stand behind them either. Lemons
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Posted on Aug 19, 2008
Pilot light on Intertherm MG 075A furnace will not stay lite on windy days. Worked fine for 20 years but has been a problem the last couple of winters. thermocoupler has been replaced a couple of ti
If this really is a thermocouple unit with a standing pilot, it must be pre 1978, I would suspect a crack in the exchanger first off as thats potentially lethal, not a joke, many heart attacks, headaches, fibromyalgia etc comes from undiagosed carbon monoxide exposures!
And many die from it sadly as it is 100% preventable, a detector would be advised even if you are ok there. A draft can be from the roof car ruting out or misssing? any dryer, Jennair, bath fan, water heater, stove top and many hvac systems create negative pressure in the home by exhausting air and not returning any or less than removed, as in a leaky supply duct leaking in the attic, the furnace pulls X cfm and returns Z
and fireplaces etc will backdraft. gas valves do get tired too.
Oct 31, 2012 | Dayton Gas Furnace Heater
How to cancel f9 code
JennAir F code 9
F9 Door lock safety circuit on power relay board sensed Replace power relay board
Nov 10, 2009 | Kitchen Ranges
CFM's pushed out by blower for jennair S176W range
hi there,
initially downdraft ranges from 6oo CFm to 1600 CFM within the pushbutton control.
CFM means (cubic feet of evacuated air per minute)
Hope this initial info/idea helps.
Let me know for further clarifications,
Jun 04, 2009 | Jenn-Air JES9860 Electric Kitchen Range
I wanted to know how many Jennair downdraft electric ranges were out in 2000, with a sealed 2 unit burner and a grill and are there still replaceable plug in units for them?
Modules are still available for some models but you need the model and serial numbers of the range to find out what is available to fit it. The customer service number for Jenn-air is
800-536-6847. You might call a local appliance store if they carry Jenn-air products.
Jan 01, 2009 | Kitchen Ranges
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
364 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
