Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Air filter error message
I can not find the air filter on my tv, what do I need to do to take care of this error message. TV shuts off 1 min after error msg appears. thanks
  • stilwant2 Aug 04, 2008
    cant find filter
Remove all the screws from the lower panel the ones with the arrows , after all the screws are removed the lower panel should come out , in the very center of the tv inside you will see some wires in front of a black plastic cover about 6" X 3" .carefully move the wires out of the way by moving them down . after the wires are moved get a phillips screw driver with a magnetic tip memove the screws from black cover be very carefull not to drop the screws into the tv . after the screws are removed carefully pull the black cover off . under the cover youll see the "AIR FILTER" carfully pry the filter out i used a butter knife .
take out the filter and blow it out using light air pressure. the filter may look clean but its not ,check it by putting a flashlight on the filter and looking through it before and after . to reinsstall just reverse the process.. before i discovered this i called panasonic directly they stated i had to take it to a authorized service center, i called a center and they said $350.00 for a house call and 250.00 if i brought it to them .
good luck i hope i saved you some money !
Posted on Jan 08, 2009
  • eeb_guerrero Feb 01, 2011
    That's exactly what I did, watch the little screws when you reinstall.
Open the back. There is a center piece in middle. Pull this out and there are two metal filters on either side. pull out filters and wipe with clean cloth. Put everything back and thats it.
Posted on Dec 01, 2008
    New Friend:
  • 21 Answers
Hi there. You won't see any obvious air filters like the old sets....
Fan 1 is used for air filter detection. Fan 1 plug P2902 at the right side of the light engine board may not be making good contact or simply isn't running. The feedback sensor built into the fan tells the micro what's up with the cooling system. If the fan isn't happy, neither is the set.
This needs to be checked by a qualified repairman, since if there actually is a clogged filter (very rare), some significant disassembly is required...
Good luck, Mark
The TV keeps shutting down due to over heating. Is there something that needs to be cleaned?
Yes you need to clean the AIR FILTER located in TV.
Please follow the steps below to clean it.
1. Turn the television off and unplug the AC cord.
2. Locate the dust filter on the left side panel of the TV.
3. Using a phillips screwdriver, remove the two screws that hold the dust filter cover in place.
4. Remove the filter cover, set it and the screws aside.
5. Carefully remove the filter from the TV.
6. Clean the filter material by dusting with a lint-free cloth.
7. If the filter is soiled, you can rinse it with water. Do not use detergents or soap on the filter.
8. Completely air dry the filter before placing it back into the TV.
9. Replace the filter cover and secure with the screws.
For showing location i have attached a image.
Thanx
Jul 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air Filter Cleaning
Call the factory for an authorized servicer near you, your TV guy doesn't understand Panasonic...
If the lamp thermal sensor is active, the fans just keep running because it thinks the thing is hot (to save an expensive part from exploding). It does not give any error message.
Fan 1 is used for air filter detection. (It's essentially the same run-sensor type fan used in their stereos.) Fan 1 plug P2902 at the right side of the light engine board may not be making good contact or the fan is not running. The micro must get the proper feedback signal from that fan to keep it happy.
Good luck, Mark
Jul 23, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Air Filter Cleaning error message
There are indeed 2 air filters on the light engine. To clean these, it is necessary to open up the television's back lower panel, remove an electrical component, then slide out the projection unit (you must be very careful - this is over $600 to replace if you break it). The air filters are pretty easy to clean...I used gentle strokes from a soft bristle hobby paintbrush and blowing (I wouldn't recommend using a can of compressed air for this...these filters are somewhat fragile). Dust out the rest of the unit pretty good (use EXTREME caution when doing this). Then put everything back together, and then you have to go through the re-alignment procedure. You can obtain the technical service manual on the Internet...sorry, but I can't help you find it...I am not sure about the legal/copyright ramifications of distributing the manual w/o Panasonic's permission...but its out there...Google is your friend. I would NOT attempt this repair without this manual...it contains crucial diagrams, and "gotcha" warnings (like what order to tighten screws for example). This isn't a hard repair if you just take the time to prepare, move slowly and methodically, and don't be in a rush. Good Luck!
Jun 27, 2008 | Panasonic PT-44LCX65 Television
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Filter cleaning issue
Try making sure that your cable box is turned on (if you have one) then try the volume down button (on the tv) at the same time as the tv/video button (on the remote).
If that works please post back about how you got past the first menu that does not allow you to reset the air filter hours...
We have the same issue and we cannot get past that menu.
I don't think we have an air filter???
Jan 10, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Message on screen says tv will shut down ck air vents for blocks
you must have a wd series mitsubishi..the lamp tempurature sensor has a manufacturing problem..mitsubishi has an updated one to take care of the problem..the sensor itself is not bad it is the way the wires are crimped in the plug,,the new one is soldered..the part number is 299P313010A,
Sep 17, 2007 | Mitsubishi WD73727 73" HDTV
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
265 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
